[Aust-NZ] GIS is dead [SEC=UNCLASSIFIED]
Roppola, Antti - BRS Antti.Roppola at brs.gov.au
Mon Oct 8 19:39:59 EDT 2007
 Tim wrote:
> OK, so mostly it's not high end GIS analysis by any means, but that
> type of integration between spatial data and general IT systems is
> where most of the action is, rather than traditional GIS. In other
> words, we're seeing spatial become just another component of
enterprise solutions.
> Traditional proprietary GIS vendors from what I've seen by and large
> haven't moved with the times (ok, I'm thinking of one vendor in
> particular here...).  They're still pushing the "walled in garden"
Some personal thoughts...
Most of the major vendors have enthusiastically jumped on the enterprise
bandwagon. In the last couple of conferences I've been to, I've seen the
broad message has shifted from "spatial is special" to "spatial is not
special". I think the idea is that all of them would like to occupy the
same sort of niche that Oracle occupies in the corporate data centre
(GIS is part of the enterprise as long as it's our GIS). But those
aspirations are going to be a lot harder to realise in the current
market than in the late 80's (where software wasn't a commodity).
Their ability to keep a walled garden will depend to a great extent on
how compelling a proposition they can make. I'd suspect that the
incumbents (Google, MS, Oracle and the Burgeoning array of FOSS) will
not be too keen to let "them" build something like that uncontested.
Cheers,
Antti
------IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
More information about the Aust-NZ mailing list
