[Aust-NZ] GIS is dead
Bruce.Bannerman at dpi.vic.gov.au Bruce.Bannerman at dpi.vic.gov.au
Mon Oct 8 21:49:05 EDT 2007
Tim,
IMO:
A good analysis.
I've interpreted your argument to be: "GIS (spatial) is so successful that
everyone wants a piece of the action."
Taking this further 'spatial' is now taking over the (IT) world. This is a
far cry from being dead.     ;-)
wrt "walled in gardens", I can understand why organisations want to
protect their turf (and investment). Even one of your 'open' examples,
Google likes to play in its own world. Consider how long it has taken for
them to support WMS.
It will take some time for some organisations to appreciate that they
could get benefit by allowing interoperability. It will also require
purchasing organisations to specify 'open standards' as a pre-requisite in
their tender specs before the message is really listened to.
wrt 'traditional' GIS. This is also far from dead. It will be a long, long
time before everything spatial can be done in a browser. What it comes
down to is to choose the appropriate tool for the job.... and make sure
that it doesn't tie up your data.
Bruce
Tim Bowden <tim.bowden at westnet.com.au>
Sent by: aust-nz-bounces at lists.osgeo.org
08/10/2007 11:14 PM
To
Aust-NZ OSGeo <Aust-NZ at lists.osgeo.org>
cc
Subject
Re: [Aust-NZ] GIS is dead
On Mon, 2007-10-08 at 09:09 +1000, Bruce.Bannerman at dpi.vic.gov.au wrote:
> Tim,
> IMO:
> In a world of climate change and water shortage issues just begging
> for some good spatial/image/temporal analysis, I find it difficult to
> understand that 'GIS is Dead'.
Ok, so the GIS is dead claim is a little tongue in cheek, but only
slightly.  If we look at traditional GIS, we see a bunch of tools that
are designed for use by highly trained experts.  We see vendors creating
GIS ecosystems that are closed environments; "walled in gardens" for
want of a better expression, that try and limit interoperability with
other vendors tools.  We see a big disconnect between GIS systems and
general IT systems.
Now compare that to what's happening in the wider spatial world.  Google
maps and similar offerings (for all the technical shortcomings of the
various systems) have helped create a mindset change about how spatial
data is being used.  The big advances in integrating spatial data into
everyday IT systems mostly isn't coming from companies like ESRI.  If
you want to have a look at what's happening, you're better of turning to
companies like Nokia, who are taking spatial data and integrating it
into everyday systems.
There are people doing "GIS" now who haven't even heard the term.  Think
accountants doing spatial analysis on asset management systems,
insurance brokers doing spatial risk analysis, transport managers using
mapping capabilities build into their scheduling software.  They don't
know what GIS is, and they don't need to know.  They just need the tools
that allow them to make use of the spatial data they have, and that's
happening.  Look at the spatial capabilities of python, java, perl or
whatever your favourite development environment is.  All the standard
"GIS" capabilities are available there.  It's our responsibility as
"GIS" professionals to try and make these tools as "idiot proof" as
possible, and help guide people in the best use of them, but for good or
ill, there are probably more people using them who don't know GIS than
who do.  There will increasingly be more spatial activity outside the
traditional GIS space than inside it.
OK, so mostly it's not high end GIS analysis by any means, but that type
of integration between spatial data and general IT systems is where most
of the action is, rather than traditional GIS. In other words, we're
seeing spatial become just another component of enterprise solutions.
Traditional proprietary GIS vendors from what I've seen by and large
haven't moved with the times (ok, I'm thinking of one vendor in
particular here...).  They're still pushing the "walled in garden"
closed ecosystem, which doesn't make for a good enterprise spatial data
management approach.  Enterprise solutions need to be able to manipulate
data using any number of tools, and have the data available in open
accessible formats.  Spatial data then becomes just another attribute in
bigger enterprise wide data sets, rather than being in a separate
specialised system that only GIS experts can access.
That's why traditional GIS is "dead".
Sure, there will always be a need for specialist GIS services, but heavy
analysis tools are increasingly going to be a smaller and smaller part
of the spatially enabled enterprise solution set.
Anyone want to chip in on this?  If you think I'm wrong, I'd like to
know!
Regards,
Tim
Aust-NZ mailing list
http://lists.osgeo.org/mailman/listinfo/aust-nz
Notice:
This email and any attachments may contain information that is personal,
confidential, legally privileged and/or copyright.No part of it should be reproduced,
adapted or communicated without the prior written consent of the copyright owner.
It is the responsibility of the recipient to check for and remove viruses.
If you have received this email in error, please notify the sender by return email, delete
it from your system and destroy any copies. You are not authorised to use, communicate or rely on the information
contained in this email.
Please consider the environment before printing this email.
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20071009/55b477a7/attachment.html
More information about the Aust-NZ mailing list
