[Aust-NZ] Inquiry into Improving Access to Victorian Public Sector Information and Data
Cameron Shorter cameron.shorter at gmail.com
Mon Aug 11 00:16:50 EDT 2008
Understood Bruce.
With my OSGeo hat on: if you write a submission, I'd be happy to review
and add suggestions.
Bruce.Bannerman at dpi.vic.gov.au wrote:
> IMO:
> Cameron,
> I have given this some thought over the last few days, particularly
> after reading through the Inquiry's discussion paper.
> There are significant spatial issues that need to be addressed in
> their own right.
> Therefore, I think that it would be appropriate to address this under
> a separate submission, that was focussed mainly on spatial.
> As an OSIA list member, I'm happy to share what I come up with, if
> there is interest.
> Regards,
> Bruce Bannerman
> Cameron Shorter <cameron.shorter at gmail.com> wrote on 07/08/2008
> 02:44:35 PM:
> > Introductions:
> > Open Source Industry Australia (OSIA) meet
> > the Australian/New Zealand chapter of the Open Source Geospatial
> > Foundation (OSGeo).
> > (and visa-versa)
> > As I understand it, individuals from both email lists are planning to
> > write a response for this Public Access to Data Proposal and I suspect
> > all responses will have a similar message.
> > In particular, interest has been shown from:
> > Brendan Scott, Adam Crow from OSIA
> > Bruce Bannerman, Bruce Bannerman, and maybe Rob Atkinson from OSGeo
> Aust/NZ.
> > I suggest consider writing a polished joint submission which should be
> > better as it has more inputs and reviewers.
> Notice:
> This email and any attachments may contain information that is
> personal, confidential,
> legally privileged and/or copyright. No part of it should be
> reproduced, adapted or communicated without the prior written consent
> of the copyright owner.
> It is the responsibility of the recipient to check for and remove viruses.
> If you have received this email in error, please notify the sender by
> return email, delete it from your system and destroy any copies. You
> are not authorised to use, communicate or rely on the information
> contained in this email.
> Please consider the environment before printing this email.
> Aust-NZ mailing list
> Aust-NZ at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/aust-nz
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Aust-NZ mailing list
