[Aust-NZ] Re: FOSS4G2009 PCO selection
Cameron Shorter cameron.shorter at gmail.com
Fri Feb 29 14:54:56 EST 2008
Bruce,
I'm sorry that you were unable to review the PCO tender document. Your
experience writing and reviewing tenders would have been excellent.
I'm hopeful that you will be available to help evaluate and select a PCO?
There are a couple of others on this list with similar experience
reviewing tenders. Please speak up if you can make yourself available to
review and select a PCO and I'll make sure you are notified and consulted.
Bruce.Bannerman at dpi.vic.gov.au wrote:
> IMO:
> In the future, can we get a bit more time to review documents before
> they need to be actioned?
> I sat down to have a look at this on the train this morning (earliest
> opportunity) only to realise that the document had already gone out.
> I'm sure that I'm not the only one with time pressures.
> Bruce
> shoaib <saburq at gmail.com> wrote on 24/02/2008 10:57:35 PM:
> > Thanks Marie-Claire and Cameron
> > I've updated with it with your changes.
> > I've added 2 points to the selection criteria:
> > 1. Strength in online marketing.
> > 2. Experience with marketing in Asia (esp. evidence of marketing
> > success in Asia Pacific)
> Notice:
> This email and any attachments may contain information that is
> personal, confidential,
> legally privileged and/or copyright. No part of it should be
> reproduced, adapted or communicated without the prior written consent
> of the copyright owner.
> It is the responsibility of the recipient to check for and remove viruses.
> If you have received this email in error, please notify the sender by
> return email, delete it from your system and destroy any copies. You
> are not authorised to use, communicate or rely on the information
> contained in this email.
> Please consider the environment before printing this email.
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Aust-NZ mailing list
