[Aust-NZ] Merging new developments into core (was: Finding a way
forward)
Jeroen Ticheler
Jeroen at ticheler.net
Tue May 20 07:14:34 EDT 2008
Hi Simon and others,
I'm reading through the interesting archived discussions you have on
the aus-nz list (only just subscribed).
> Up until last month we've fed a lot of the code from the MEST back
> into the trunk but there is a need to write proposals and get them
> approved by the community before some of the later changes can be
> committed. Community approval is a good thing but it takes time to
> get this together and slot things in to the trunk - that time lag
> would be a problem for anyone (not just BlueNet) - especially when
> the priority for us has been features we need.
I'm getting quite concerned when I read this, as I feel that putting
such procedures in place should have minimum effect on the normal
development process. What it should do is start some discussion where
needed and help to ensure that not just anything will get into core.
Proposals do not have to be endlessly long either.
We need to find a good way of dealing with this, since delaying to add
new developments to core may in the end be the cause of a fork if your
developments deviated to much from trunk. Add to that the fact that
you have moved on to new stuff, it becomes even more likely we'll
never see the change merged back. :-(
At this point I want to have some discussion on the GeoNetwork
developer list to find a good working solution. The most obvious one
for me is to have sandboxes set up for those that develop new
functions. This will allow a developer to just do his work as normal,
but has the big advantage that others can see what's happening and can
be informed on forehand. So when time comes to merge new code to
trunk, we already had a chance to see the code (through commit mailing
list for instance) and the process of a proposal and voting would be
slimmed down a lot.
Looking forward to some good discussion on this.
Ciao,
Jeroen
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20080520/20676644/attachment.html
More information about the Aust-NZ
