[OSGeo-Standards] Re: [Aust-NZ] ESRI/Google indexing spatial data.Where is OGC?
Bruce.Bannerman at dpi.vic.gov.au Bruce.Bannerman at dpi.vic.gov.au
Tue May 27 19:40:15 EDT 2008
IMO:
Jo,
> Cameron, your call for "standards" for web-based spatial data search
> would be well-placed if there were any available that had proven their
> worth, but I don't see that there is anything of proven worth yet -
> it is too early to tell which approaches are going to work.
> This does *not* seem like a problem that is proving tractable to
> upfront formalisation. I have *not* been able to persuade anyone to
> change their approach just through discussion. The OGC recommendations
> with CSW and the ISO standards for data and service metadata haven't
> demonstrated much widespread use or technical success yet.
> What's changing?
Have a look at: http://asdd.ga.gov.au/asdd/tech/zap/basic.html
Try searching for any type of data that takes your fancy.
The ASDD entry page will take this search and query a federated set of
other metadata catalogues.
This is an example of what can be done with current standards (also the
basis of those supported by CSW).
There used to be a similar entry page on the GSDI web site, but I can't
seem to find it this morning.
Bruce Bannerman
Notice:
This email and any attachments may contain information that is personal,
confidential, legally privileged and/or copyright.No part of it should be reproduced,
adapted or communicated without the prior written consent of the copyright owner.
It is the responsibility of the recipient to check for and remove viruses.
If you have received this email in error, please notify the sender by return email, delete
it from your system and destroy any copies. You are not authorised to use, communicate or rely on the information
contained in this email.
Please consider the environment before printing this email.
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20080528/594b2124/attachment.html
More information about the Aust-NZ mailing list
