[Aust-NZ] Logo 5 version 2 release candidate 37
Jody Garnett jgarnett at refractions.net
Mon Sep 8 03:55:05 EDT 2008
Hamish wrote:
> Jody wrote:
>> I would like to thank Hamis for the the advice on star placement :-) I
>> took your image and rotated it to match the orientation of the two flags
>> and then repositioned the starts in the correct place. The result looks
>> spot on ...
> Nice work Jody. It looks good.
> The only slight change I would investigate would be to rotate the stars +
> button by 10-15 degrees counter-clockwise. It's a bit silly but my eye
> wants to see the thing balance on Acrux.
I am not sure I understand; the two stars making the line of the crux
are lined up vertically?
> Maybe that is broken physics, but who said aesthetics were entirely logical? Besides that reason it
> makes the logo look slightly less harsh if the graphic doesn't perfectly
> snap to a vertical grid line.
Not broken physics; just which way you happen to be facing when looking up.
Okay let us give that a go - file is attached.
I do not mind either way.
Jody
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/aust-nz/attachments/20080908/27b15295/OSGeo_Aust_NZ_4-0001.png
More information about the Aust-NZ mailing list
