[Aust-NZ] Statistics New Zealand RFQ specifies ESRI but not OGC standards
Cameron Shorter cameron.shorter at lisasoft.com
Fri Sep 2 01:34:08 EDT 2011
Something which our New Zealand subscribers may wish to pursue:
Statistics New Zealand has just put out a RFP for "SP3-A83 Geospatial
Infrastructure Project" which specifies ESRI, but doesn't specify OGC
standards.
I suspect this conflicts with New Zealand's SDI strategy?
https://www.gets.govt.nz/Default.aspx?show=TenderDetail&TenderID=33952&returnTo=home
The vision of the Geospatial Infrastructure project is that "Statistics
New Zealand becomes spatially enabled". This project will develop the
core geographic infrastructure required to achieve spatial enablement --
an address point-based geographic frame using geospatial technology.
This project is the legacy mitigation solution to replace the current
text-based 'Geoframe' and the plethora of standalone systems and manual
processes currently in use by Statistics New Zealand.
A 'Geospatial Management System' (GMS) will be developed in a Geographic
Information System using ESRI ArcGIS. The management and maintenance of
Statistics New Zealand's core geographic infrastructure, including
addresses, meshblocks (Statistics NZ's building block geography) and
derived geographies, will be centralised within a spatial environment.
The consultant/s will be responsible for:
1. assisting Statistics NZ with the implementation and configuration of
geospatial software and data
2. assisting Statistics NZ with configuring business and software rules
3. providing support documentation for all implementation and
configuration activities, and
4. up-skilling Statistics New Zealand staff on the above services.
On 1/09/2011 8:26 PM, info at gets.govt.nz wrote:
> *GETS Tender Watch Notifications for Thursday, 1 September 2011*
> Please find below the latest opportunities that match your profile.
>  1. Please LOGIN to GETS - www.gets.govt.nz <http://www.gets.govt.nz>
>  2. Once successfully logged into GETS, either click TenderWatch
>     <http://www.gets.govt.nz/Default.aspx?show=Tenders&Nav=Supplier>
>     or hyperclick from the email shortcut(s) below
>  3. To view the full range of tenders and opportunities, click on GETS
>     Tender Opportunities
>     <http://www.gets.govt.nz/Default.aspx?show=Tenders&Nav=ATenders>
> *NEW ZEALAND*
> *ICN REF* 	*Description* 	*Purchaser* 	*Respond by*
> 33957
> <http://www.gets.govt.nz/Default.aspx?show=TenderDetail&TenderID=33952>
> SP3-A83 Geospatial Infrastructure Project 	Statistics New Zealand
> 23/09/11
> To amend your TenderWatch codes, please login to GETS and go to the
> "Select your TenderWatch Codes
> <http://www.gets.govt.nz/Default.aspx?show=MyTenderCodes>" option
> To unsubscribe from these TenderWatch emails, please reply to this
> message and enter UNSUBSCRIBE in the Subject field
> Please note that contact details for GETS support have changed. GETS
> is now provided by the Ministry of Economic Development, PO Box 1473,
> Wellington, New Zealand. Telephone: +64 4 474 2963. Fax: +64 4 499
> 8508 Email: margaret.sullivan at med.govt.nz
> <mailto:margaret.sullivan at med.govt.nz>
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20110902/6bcc7dcf/attachment.html
More information about the Aust-NZ mailing list
