[Aust-NZ] VicMap API JavaScript - who's the developer?
Noli Sicad
nsicad at gmail.com
Tue Sep 27 20:56:28 EDT 2011
Hi Justin,
Thanks a lot.
Basically that's what I want at this moment (i.e. a Base map / layer) :-).
Noli
On 9/28/11, Justin Madex <justin.madex at gmail.com> wrote:
> Hi Noli,
> Sorry for the delay, been flat out at work.
> Vicmap API's was planned to be only used as a base layer on a map due to a
> few restrictions.
> - that's the intention of DSE
> - the tiles are not transparent
> - Vicmap API only supports the predefined 14 zoom levels/scale
> That said, you can still use it as a wms layer but you will need to use the
> projection EPSG:3111
> See the following sample code:
> <script type="text/javascript">
> var map;
> var layer;
> var lon = 2439245.01855;
> var lat = 2526943.49665;
> function init()
> var options = {
> projection : new OpenLayers.Projection("EPSG:3111"),
> map = new OpenLayers.Map( 'map', options );
> var basemap = new OpenLayers.Layer.WMS( "vicmapapi",
> "http://lctest.land.vic.gov.au/vicmapapi/map/wms",
> layers: 'CARTOGRAPHICAL',
> format: 'image/png',
> transparent: 'off'
> maxExtent: new OpenLayers.Bounds(1749210.30515,
> 2010475.79705, 3336713.48015, 3066694.57615),
> maxResolution: 'auto'
> map.addLayer(basemap);
> map.setCenter(new OpenLayers.LonLat(lon, lat));
> map.addControl( new OpenLayers.Control.LayerSwitcher() );
> </script>
> I hope this helps. Give me a shout if you have any questions
> - Justin
> On 28/09/2011, at 9:11 AM, Noli Sicad wrote:
>> Hi Justin,
>> I have not heard from you.
>> Here's (code below) again, VicMap WMS code that is not working.
>> <script src="OpenLayers.js"></script>
>> var map, layer, a, b;
>> a=new
>> OpenLayers.Bounds(1786000.0,1997264.499195665,3953471.00160867,3081000.0);
>> b="Vicmap API © 2011 State Government of Victoria";
>> function init(){
>> map = new OpenLayers.Map( 'map' );
>> layer = new
>> OpenLayers.Layer.WMS("VicMap","http://116.240.195.134/vicmapapi/map/wms",
>> {layers:'VicMap',format:"image/png",firstTile:true},
>> {tileSize:new OpenLayers.Size(512,512),tileOrigin:new
>> OpenLayers.LonLat(-34932800,57119200),isBaseLayer:true,
>> buffer:0,maxExtent:a,attribution:b});
>> map.addLayer(layer);
>> map.zoomToMaxExtent();
>> </script>
>> Anybody in the list knowledgeable how to fix this code to make it working?
>> Thanks.
>> Noli
>> On 9/27/11, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi Justin,
>>> Thanks for replying.
>>> I sent you an email on the details of my problem using VicMap WMS
>>> (offline the Aust-NZ list).
>>> Thanks.
>>> Noli
>>> On 9/27/11, Justin Madex
>>>> Hi Noli,
>>>> I work for Dialog IT and we developed VicMap API
>>>> Was there an issue you were experiencing?
>>>> - Justin
>> Aust-NZ mailing list
>> Aust-NZ at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/aust-nz
More information about the Aust-NZ
