[Aust-NZ] Please update NSW Procurement guidelines to align with Australian Open Source Policies
Cameron Shorter
cameron.shorter at lisasoft.com
Thu Nov 20 01:41:13 PST 2014
To the NSW Procurement Team,
We, the Australian and New Zealand chapter of the Open Source Geospatial
Foundation, are concerned that NSW Procurement guidelines about Open
Source Software are dated and need to be changed.
The guidelines:
* Inaccurately imply Proprietary Software is less risky than Open Source
[1],
* Unfairly discriminate against Open Source Software solutions and
Australian Open Source businesses [1],
* Conflict with Australian government policy which directly mandate that
Open Source and Proprietary Software should be considered equally. [2]
* Increases the cost and reduce the value of NSW Government IT purchases
by actively discouraging use of Open Source.
Could the NSW Procurement Team please review the current Open Source
statement, assess the appropriateness of updating to Australian
Government Policy statements related to Open Source, and reply
describing how you plan to address this issue.
*Reference 1:*
The NSW IT procurement framework (version 3.1) specifically discourses
use of Open Source software with Major Project System Integration Services.
/23 Open Source Software //
//23.1 The Contractor must ensure that: //
//(a) none of the Deliverables comprise Open Source Software; and //
//(b) it does not insert any Open Source Software into the Customer
Environment, except to the extent otherwise approved by the Customer in
writing. //
//23.2 Where the Customer gives its approval in relation to the use of
any Open Source Software //
//under clause 23.1: //
//(a) the Contractor must ensure that the use of that Open Source
Software will not result in an obligation to disclose, license or
otherwise make available any part of the Customer Environment or any of
the Customer'sConfidential Information to any third party; and //
//(b) the use of that Open Source Software will not in any way diminish
the Contractor's obligations under the Contract, including without
limitation in relation to any warranties, indemnities or any provisions
dealing with the licensing or assignment of Intellectual Property. /
https://www.procurepoint.nsw.gov.au/before-you-supply/standard-procurement-contract-templates/procure-it-framework-version-31
See: Module 13A Major project systems integration services
*Reference 2:*
Australian Government Policy on Open Source Software:
/Principle 1: Australian Government ICT procurement processes must
actively and fairly consider all types of available software.//
//Australian Government agencies must actively and fairly consider all
types of available software (including but not limited to open source
software and proprietary software) through their ICT procurement
processes. It is recognised there may be areas where open source
software is not yet available for consideration. Procurement decisions
must be made based on value for money. Procurement decisions should take
into account //
//whole-of-life costs, capability, security, scalability,
transferability, support and manageability requirements.//
//For a covered procurement (over $80K), agencies are required to
include in their procurement plan that open source software will be
considered equally alongside proprietary software. Agencies will be
required to insert a statement into any Request for Tender that they
will consider open source software equally alongside proprietary
software. Tender responses will be evaluated under the normal
requirements of the Commonwealth Procurement Guidelines. For a
non-covered procurement (below $80K), agencies are required to document
all key decisions, as required by the Commonwealth Procurement
Guidelines. This includes how they considered open source software
suppliers when selecting suppliers to respond to the Select Tender or
Request for Quotation.//
Australian Government Policy on Open Source Software,
http://www.finance.gov.au/policy-guides-procurement/open-source-software/
Cameron Shorter,
President of the Australian Chapter of the Open Source Geospatial Foundation,
Software and Data Solutions Manager, LISAsoft
Suite 112, Jones Bay Wharf,
26 - 32 Pirrama Rd, Pyrmont NSW 2009
P +61 2 9009 5000, Wwww.lisasoft.com, F +61 2 9009 5099
The contents of this email are confidential and may be subject to legal or
professional privilege and copyright. No representation is made that this
email is free of viruses or other defects. If you have received this
communication in error, you may not copy or distribute any part of it or
otherwise disclose its contents to anyone. Please advise the sender of your
incorrect receipt of this correspondence.
URL: <http://lists.osgeo.org/pipermail/aust-nz/attachments/20141120/a59d7985/attachment.html>
More information about the Aust-NZ
