[RNFdev] Re: RNFdev Southern Ontario FSA Border Streets
Sampson, David dsampson at NRCan.gc.ca
Mon Sep 25 13:13:23 EDT 2006
Dan,
The original PDF is found here
http://www.canadapost.ca/cpc2/addrm/hh/maps/FSA/ON06.pdf
I have attached the Ottawa FSA list. I assume that's what you were
looking for.
I also included a fixed document.
I sent the DOC format but I can convert to DBF if required.
I provided the fixed doc so he can compare the two and see some of the
common mistakes. This was a manual edit and still might have some errors
as I did not cross reference EACH road name. But it should suffice.
One record per line
Cheers
-----Original Message-----
Sent: September 25, 2006 11:49
To: can_rnf at geodata.osgeo.org
Subject: [RNFdev] Re: RNFdev Southern Ontario FSA Border Streets
Hi Dave,
I don't know if he has joint the list, but he sent me email on this
issue. To that end, could you send me the original address file for
Ottawa so he has something to test with? My guess is as to what will
work best is if each road is placed in a single data value. For example:
LANDSDOWNE RD S
Given that PAGC's I/O is based on Frank's Shapelib, things will work
best if this single field database is saved in a dbf file. Walter can
then produce a standardized file that conforms to the StatsCan RNF
structure. Road names are another issue. However, we can use a set of
unique road names taken from the RNF for an area and then match the
Canada Post road names to them using PAGC's existing matching routines.
Once I get the Canada Post Ottawa file from you, I can quickly generate
the StatsCan RNF road names and them along to Walter.
Dan
On 25-Sep-06, at 5:48 AM, Sampson, David wrote:
> Hey Folks,
> I am taking a look at southern Ontario, specifically St Catherines and
> GTA.
> I tried to come up with a systematic search and replace for St
> Catherines and only had a few instances that I needed to check the PDF
> for varification. Ther are not many names on that map.
> The GTA though is a whole new ball game (20 pages at 12 pt font after
> removing all FSA codes)....  Within the first page I would say close
to
> a %60-70 check back ratio, where I needed to check the original PDF
> and the names did not appear in a predicatble manner.
> For instance prefix or suffix would apear 2 to three lines previous or
> after the name of the road. And also some names were split due to
> length. It is less teadious when names and prefix/suffix occur on
> sequential lines. One process I used was to replace any manual line
> break with nothing, making the whole document one continuous text
> string. And then replacing key SUFFIX's with a coma (,) and a line
> break. The comman was a reminder than the name has been process, and
> the line break makes it an independent record.
> I would use common ones like RD, ST, CIR, AVE etc and for smaller
> areas this worked quite well for a process, but had no means of
> verifying if the names are what they are supposed to be.
> I explored the concept of using th RNF DBF as an Excell Verticle
> lookup table, but Excell is limited after that. A Vertcile lookup
> table can be used to check a given value (eg suggested road name text
> string) against a standard list. This is a dirty approach but I can
> keep exploring it.
> Does Walter have any ideas as to how we can process the raw names and
> try to standardize them?
> Although it IS possible to manualy match street names for the GTA this
> would be nothing less than a Nobel task.
> Cheers
Type: application/msword
Desc: FSA_Ottawa_RDBND.doc
Url : http://lists.osgeo.org/pipermail/can_rnf/attachments/20060925/78435e7a/FSA_Ottawa_RDBND.doc
Desc: FSA_Ottawa_RDBND(fix).doc
Url : http://lists.osgeo.org/pipermail/can_rnf/attachments/20060925/78435e7a/FSA_Ottawa_RDBNDfix.doc
More information about the Can_rnf mailing list
