[RNFdev] CSD and RNF
Dan Putler putler at sauder.ubc.ca
Mon Sep 25 17:20:13 EDT 2006
Yes, using the CSDs in this way is the plan. However, the CSDs I'm
using at the moment can't be publicly released. StatsCan will be
releasing the 2006 CSD polygon layer to the public in the next few days.
Dan
On 25-Sep-06, at 12:11 PM, Sampson, David wrote:
> Dan,
> The CSD shpae files you are using. Could it be used for splitting
> up the RNF based on city… or adding city reference to the RNF?
> Is it in the same projection?
> Do CSD's have names or numbers?
> Could they be used as a cookie cutter approach for city sized or
> regional sized road networks?
> Cheers
More information about the Can_rnf mailing list
