[cat-interop] Metadata link types vocabulary proposal
Signell, Richard rsignell at usgs.gov
Wed Mar 5 09:10:38 PST 2014
I like the git idea, but would vote for osgeo github as a location, if
only because it has more name recognition at this point.
On Wed, Mar 5, 2014 at 8:54 AM, Jeroen Ticheler
<jeroen.ticheler at geocat.net> wrote:
> Hi Tom and others,
> We are working on getting metadata profiles developed in a separate git repository https://github.com/metadata101 and published under http://metadata101.org . This allows people to work on a range of metadata profiles while maintaining a common basis, so that applications can use these profiles from a single source.
> Would you be open to the idea to also host the vocabularies under that same umbrella? It would not be related to a specific project or foundation, which could help to get wide acceptance across open source and proprietary applications. This would be a great benefit for interoperability in my opinion.
> A build process could ensure the vocabularies are kept up to date under http://metadata101.org while they are developed and versioned on Github.
> My 2 cents,
> Jeroen
> On 5 mrt. 2014, at 14:12, Tom Kralidis <tomkralidis at gmail.com> wrote:
>> Thinking this though more, I think the way forward here is for this
>> to be an OSGeo vocabulary, which we can build and manage under
>> http://osgeo.org/vocab like:
>> http://osgeo.org/vocab/data/{provider}/{type}[/version]
>> http://osgeo.org/vocab/service/{provider}/{type}[/version]
>> Then providing a thin resolution layer, members of this vocabulary, when
>> invoked via HTTP, would then dereference/resolve accordingly.  Like:
>> http://osgeo.org/vocab/service/ogc/sos/1.0
>> would resolve to:
>> http://www.opengis.net/sos/1.0 (which then resolves as per the
>> authoritative provider's wishes).
>> This provides the following benefits:
>> 1./ metadata clients/servers can bind to the OSGeo vocabulary, thus
>>    realizing the core goal of a harmonized link type list
>> 2./ anyone who really wants to invoke / resolve these can do so
>> 3./ This keeps OSGeo as a just a gatekeeper / custodian of the list with
>>    redirects as appropriate, which gets us out of the complexity of
>>    managing these across standards orgs/etc.
>> Comments?  I've written a small Flask app to act as a high level
>> resolver, based on our link types list and will resolve / redirect
>> accordingly, which we can push forward for hosting, etc.
>> On Mon, 3 Mar 2014, Tom Kralidis wrote:
>>> Date: Mon, 3 Mar 2014 21:53:51 -0500
>>> From: Tom Kralidis <tomkralidis at gmail.com>
>>> To: Paul van Genuchten <paul.vangenuchten at geocat.net>
>>> Cc: "<cat-interop at lists.osgeo.org>" <cat-interop at lists.osgeo.org>
>>> Subject: Re: [cat-interop] Metadata link types vocabulary proposal
>>> On Mon, Mar 3, 2014 at 4:07 PM, Paul van Genuchten
>>> <paul.vangenuchten at geocat.net> wrote:
>>>> I support Stephan at this point. The semantic web can be a big consumer
>>>> of spatial data services, if we're able to optimally embed our data in
>>>> it. Linking to controlled vocabularies by url is a big facilitator.
>>> Good points.
>>>> Sure i see the point of having a urn structure as
>>>> {provider}:{type}:{identifier}:{version}. But this can also be managed
>>>> in a (skos) vocabulary-identifier-as-url by using identifiers like:
>>>> for example:
>>>> http://osgeo.org/vocab/service/ogc/wms/1.1
>>>> http://osgeo.org/vocab/service/opensearch/opensearch/2.0
>>>> and
>>>> http://osgeo.org/vocab/mediatype/esri/shapefile/1.0
>>>> http://osgeo.org/vocab/mediatype/ogc/gml/2.0
>>>> http://osgeo.org/vocab/mediatype/w3c/json-ld/1.0
>>>> or
>>>> http://osgeo.org/vocab/service#ogc_wms_1_1
>>>> http://osgeo.org/vocab/mediatype#ogc_gml_2_0
>>>> At this point we should consider if osgeo.org is the best place to set
>>>> up such a service/vocab, as this is more a data-matter then a software
>>>> matter. Should we connect with geovocab, w3c/ogc, dbpedia to have this
>>>> set up?
>>> Based on the comments on HTTP URIs at
>>> https://github.com/OSGeo/Cat-Interop/issues/3, the OGC has this at
>>> www.opengis.net.  However the structure is not SKOS-like. I guess one
>>> factor is how deep version negotiation would go.
>>> Then again, we could implement this in OSGeo and have resolver back to
>>> their authoritative resources (i.e.
>>> http://osgeo.org/vocab/service/csw/2.0.2 could resolve to
>>> http://www.opengis.net/cat/csw/2.0.2.  Does this sound useful/make
>>> sense?
>>>> If we feel osgeo.org is a good place, let's post about it in the
>>>> request-list...
>>>> _______________________________________________
>>>> cat-interop mailing list
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/cat-interop
Dr. Richard P. Signell   (508) 457-2229
USGS, 384 Woods Hole Rd.
Woods Hole, MA 02543-1598
More information about the cat-interop mailing list
