[Workshops] Re: Tutorial: Local server and printing materials
Mark Leslie mark.leslie at lisasoft.com
Sun Oct 18 02:10:33 EDT 2009
FYI: This thread was cc'd to the wrong list.
Rob Lemmens wrote:
> Ok Daniel, Thanks a lot!
> Rob.
> Dr. Ir. Rob Lemmens
> Department of Geoinformation Processing
> International Institute for Geo-Information Science and Earth
> observation (ITC)
> P.O. Box 6
> 7500 AA Enschede, The Netherlands
> phone: +31 (53) 4874529
> fax: +31 (53) 4874335
> e-mail: lemmens at itc.nl
> Website: http://www.itc.nl/about_itc/resumes/lemmens.aspx
> -----Original Message-----
> From: Daniel Branik [mailto:dbranik at arinex.com.au]
> Sent: Friday, 16 October, 2009 23:27
> To: Rob Lemmens; Cameron Shorter
> Cc: FOSS4G 2009; Mark Leslie; foss4g workshop; Jeff McKenna; Steve Walsh
> Subject: RE: Tutorial: Local server and printing materials
> Dear Rob,
> We are currently only providing one port per session room for the
> presentation computer.  You can utilise this Ethernet for your computer.
> If you require more than one computer connected you can always use the
> wireless connection for your laptop.
> From discussion with the venue no ports should be blocked.  I will be
> located in the speaker ready are onsite and will work with you to test
> and ensure that we get a working solution.
> Kind Regards
> Daniel
> From: Rob Lemmens [mailto:lemmens at itc.nl]
> Sent: Saturday, 17 October 2009 6:24 AM
> To: Cameron Shorter
> Walsh; Daniel Branik
> Thanks Cameron for your prompt reply!
> Indeed the ports may be an issue. I will be using ports 5432 and 8080
> for Postgres and Tomcat.
> Rob.
> Dr. Ir. Rob Lemmens
> observation (ITC)
> P.O. Box 6
> From: Cameron Shorter [mailto:cameron.shorter at lisasoft.com]
> Sent: Friday, 16 October, 2009 21:13
> To: Rob Lemmens
> Cc: foss4g2009 at arinex.com.au; Mark Leslie; foss4g workshop; Jeff
> McKenna; Steve Walsh; Daniel Branik
> Subject: Re: Tutorial: Local server and printing materials
> Rob,
> Jeff and Mark have been looking after workshops and tutorials.
> You will have a couple of options open to you that I can think of:
> 1. Set up your server laptop next to you in the presentation room, I
> think there are multiple ethernet ports you can connect into.
> 2. There is a LISAsoft charging station, which contains ethernet ports
> to the conference network. I expect you should be able to make use of
> that too.
> Jeff, Mark, Daniel,
> Will there be any firewall issues at SCEC which will block ports from a
> server?
> Rob Lemmens wrote:
>> Hi,
>> I don't know to whom I should ask this questions:
>> At FOSS4G, I am presenting the following tutorial:
>> Thursday October 22, 2009 15:00-16:30 Tutorial - Using ILWIS with its
>> PostGIS plug-in for raster-vector applications (Rob Lemmens)
>> During the tutorial I will be using a server in the Netherlands, but
>> ultimately this may not work and so as a alternative I would like to
>> bring a laptop to hook up to the local network at the conference site.
>> Who can I contact at the conference site to arrange this?
>> Is there a possibility to reproduce hardcopy tutorial handouts at the
>> conference site?
>> Sorry if missed some earlier communication on this.
>> Could you refer me to the right person(s)?
>> Best regards,
>> Rob.
>> /Dr. Ir. Rob Lemmens/
>> */Department of Geoinformation Processing/*
>> /International Institute for Geo-Information Science and Earth
>> observation (ITC)/
>> /P.O. Box 6/
>> /7500 AA Enschede, The Netherlands/
>> /phone: +31 (53) 4874529/
>> /fax: +31 (53) 4874335/
>> /e-mail: lemmens at itc.nl <mailto:lemmens at itc.nl>/
>> /Website: //http://www.itc.nl/about_itc/resumes/lemmens.aspx/
>> Observation (ITC)
>> Chamber of Commerce: 410 27 560
>> *E-mail disclaimer *
>> The information in this e-mail, including any attachments, is intended
>> for the addressee only. If you are not the intended recipient, you are
>> hereby notified that any disclosure, copying, distribution or action
>> in relation to the content of this information is strictly prohibited.
>> If you have received this e-mail by mistake, please delete the message
>> and any attachment and inform the sender by return e-mail. ITC accepts
>> no liability for any error or omission in the message content or for
>> damage of any kind that may arise as a result of e-mail transmission.
More information about the Conference-workshops mailing list
