[Workshops] Machine setup
Justin Deoliveira jdeolive at opengeo.org
Mon Sep 28 18:29:27 EDT 2009
Hi Etienne,
We require a JDK (not just a JRE) for GeoServer to run. Version 6 will
be fine for us.
-Justin
Etienne Dube wrote:
> Hi,
> Is there any other workshop that requires a Java JRE? We'll be using the
> Java 6 Update 16 JRE in workshop_01 (Geospatial BI with FOSS).
> Everything else is self-contained in a directory under C:\. Could Java
> be pre-installed on the machines? Any possible version conflicts (i.e.
> if anyone requires a Java 5 JRE)?
> Thanks,
> Etienne
> Mark Leslie a écrit :
>> Damnit, this one slipped past me last week.
>> All we've got going so far is
>> http://wiki.osgeo.org/wiki/FOSS4G_2009_Workshop_Computer_Setup, which
>> really isn't up to this task, and is already incomplete.  As a general
>> rule, I would prefer to have nothing installed as an automatic
>> service.  We can setup links to load applications/services as needed,
>> but it seems easiest to not have everything running by default.  That
>> way port conflicts shouldn't be a hugh issue (optimism?).
>> It will still cause collisions on install directories, in particular
>> for workshops that involve an installation step, and service names.
>> Mark
>> Justin Deoliveira wrote:
>>> Hi folks,
>>> Apologies if this has been covered already but is there a wiki page
>>> up that lists all the software that is going to be installed on all
>>> the workshop machines? I know last year we set this up and it was
>>> quite useful in order to resolve any version conflicts, and more
>>> importantly any port conflicts between running services.
>>> -Justin
>> Conference-workshops mailing list
>> Conference-workshops at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/conference-workshops
Justin Deoliveira
OpenGeo - http://opengeo.org
Enterprise support for open source geospatial.
More information about the Conference-workshops mailing list
