[Workshops] Machine setup
Justin Deoliveira jdeolive at opengeo.org
Mon Sep 28 18:50:39 EDT 2009
Cool. Just to ensure there are no conflicts i will set up GeoServer to
run on a different port than 8080. Assuming that Tomcat will be indeed
running on 8080?
Etienne Dube wrote:
> Hi Justin,
> Good, it's fine for us too. I'll put JDK 6u16 in the software to be
> installed. JAVA_HOME can point to it and our Tomcat instance will be happy.
> Etienne
> Justin Deoliveira a écrit :
>> Hi Etienne,
>> We require a JDK (not just a JRE) for GeoServer to run. Version 6 will
>> be fine for us.
>> -Justin
>> Etienne Dube wrote:
>>> Hi,
>>> Is there any other workshop that requires a Java JRE? We'll be using
>>> the Java 6 Update 16 JRE in workshop_01 (Geospatial BI with FOSS).
>>> Everything else is self-contained in a directory under C:\. Could
>>> Java be pre-installed on the machines? Any possible version conflicts
>>> (i.e. if anyone requires a Java 5 JRE)?
>>> Thanks,
>>> Etienne
>>> Mark Leslie a écrit :
>>>> Damnit, this one slipped past me last week.
>>>> All we've got going so far is
>>>> http://wiki.osgeo.org/wiki/FOSS4G_2009_Workshop_Computer_Setup,
>>>> which really isn't up to this task, and is already incomplete.  As a
>>>> general rule, I would prefer to have nothing installed as an
>>>> automatic service.  We can setup links to load applications/services
>>>> as needed, but it seems easiest to not have everything running by
>>>> default.  That way port conflicts shouldn't be a hugh issue
>>>> (optimism?).
>>>> It will still cause collisions on install directories, in particular
>>>> for workshops that involve an installation step, and service names.
>>>> Mark
>>>> Justin Deoliveira wrote:
>>>>> Hi folks,
>>>>> Apologies if this has been covered already but is there a wiki page
>>>>> up that lists all the software that is going to be installed on all
>>>>> the workshop machines? I know last year we set this up and it was
>>>>> quite useful in order to resolve any version conflicts, and more
>>>>> importantly any port conflicts between running services.
>>>>> -Justin
>>>> _______________________________________________
>>>> Conference-workshops mailing list
>>>> Conference-workshops at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/conference-workshops
Justin Deoliveira
OpenGeo - http://opengeo.org
Enterprise support for open source geospatial.
More information about the Conference-workshops mailing list
