[Workshops] Machine setup
Mark Leslie mark.leslie at lisasoft.com
Mon Sep 28 21:44:57 EDT 2009
Apache running on port 80 shouldn't be a problem, but having it running
depends on what else needs the port, and whether we need different,
conflicting configurations.
Is anyone else planning on binding something non-Apache to port 80, or
mapping the mentioned paths?
Mark
Tim Schaub wrote:
> Sorry if this is asking the obvious, but does Apache get 80 (and will it
> be running)?
> I understand the desire to limit what workshops install and run as
> services, but I think it also makes sense to limit the number of things
> that every participant has to click through.
> I was planning on writing up instructions for configuring Apache to
> proxy GeoServer on port 80 and set up an alias for the root of the
> workshop folder.
> All the OpenLayers material assumes this (http://localhost/geoserver and
> http://localhost/ol_workshop).
> I had been planning on walking participants through starting GeoServer.
>   And I had been assuming we'd have an http server running on 80 that
> could get to the workshop folder.
> Tim
> Etienne Dube wrote:
>> Yep it'll be running on 8080, but the tomcat instance will be manually
>> started during the workshop (it won't be installed as a service, only
>> launched from a batch file). Like Mark said in this thread, I think it's
>> a good idea to have nothing installed as an automatic service, to avoid
>> any port conflict.
>> Justin Deoliveira a écrit :
>>> Cool. Just to ensure there are no conflicts i will set up GeoServer to
>>> run on a different port than 8080. Assuming that Tomcat will be indeed
>>> running on 8080?
>>> Etienne Dube wrote:
>>>> Hi Justin,
>>>> Good, it's fine for us too. I'll put JDK 6u16 in the software to be
>>>> installed. JAVA_HOME can point to it and our Tomcat instance will be
>>>> happy.
>>>> Etienne
>>>>> Hi Etienne,
>>>>> We require a JDK (not just a JRE) for GeoServer to run. Version 6
>>>>> will be fine for us.
>>>>> -Justin
>>>>> Etienne Dube wrote:
>>>>>> Hi,
>>>>>> Is there any other workshop that requires a Java JRE? We'll be
>>>>>> using the Java 6 Update 16 JRE in workshop_01 (Geospatial BI with
>>>>>> FOSS). Everything else is self-contained in a directory under C:\.
>>>>>> Could Java be pre-installed on the machines? Any possible version
>>>>>> conflicts (i.e. if anyone requires a Java 5 JRE)?
>>>>>> Thanks,
>>>>>> Etienne
>>>>>> Mark Leslie a écrit :
>>>>>>> Damnit, this one slipped past me last week.
>>>>>>> All we've got going so far is
>>>>>>> http://wiki.osgeo.org/wiki/FOSS4G_2009_Workshop_Computer_Setup,
>>>>>>> which really isn't up to this task, and is already incomplete.  As
>>>>>>> a general rule, I would prefer to have nothing installed as an
>>>>>>> automatic service.  We can setup links to load
>>>>>>> applications/services as needed, but it seems easiest to not have
>>>>>>> everything running by default.  That way port conflicts shouldn't
>>>>>>> be a hugh issue (optimism?).
>>>>>>> It will still cause collisions on install directories, in
>>>>>>> particular for workshops that involve an installation step, and
>>>>>>> service names.
>>>>>>> Mark
>>>>>>> Justin Deoliveira wrote:
>>>>>>>> Hi folks,
>>>>>>>> Apologies if this has been covered already but is there a wiki
>>>>>>>> page up that lists all the software that is going to be installed
>>>>>>>> on all the workshop machines? I know last year we set this up and
>>>>>>>> it was quite useful in order to resolve any version conflicts,
>>>>>>>> and more importantly any port conflicts between running services.
>>>>>>>> -Justin
>>>>>>> _______________________________________________
>>>>>>> Conference-workshops mailing list
>>>>>>> Conference-workshops at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/conference-workshops
More information about the Conference-workshops mailing list
