[OSGeo-Conf] 2009 RFP draft review
Thierry Badard Thierry.Badard at scg.ulaval.ca
Wed Oct 24 21:55:44 EDT 2007
Frank Warmerdam a écrit :
> Jeff McKenna wrote:
>> Thanks to everyone for attending the draft meeting today.  I've
>> incorporated everyone's feedback into the document, available below.
>> Please take a look and if we don't hear anything by the end of the day
>> tomorrow we'll go ahead with the RFP release tomorrow.
> Jeff,
> The "Support by OSGeo" section still contains the phrase "It is, however,
> intended that the conference be essentially revenue neutral after
> completion."
> This needs to be changed to reflect our intent to produce a substantial
> profit for OSGeo as part of the conference.
> Best regards,
Jeff,
Here are some minor suggestions and corrections :
1) The "Committee Question Period" section mentions "A period between
the solicitation closing date and the decision date (01/11/08 to
01/25/08) ...", but the decision date is February 1st, 2008 ;-). The
sentence should then be rephrased as for instance: "A period between the
solicitation closing date, 01/11/08 and 01/25/08 ...".
2) To my mind, addition of a section entitled "Important dates" would be
a good idea. It will act as a simple and practical reminder of important
steps in the submission process.
3) In the "evaluation criteria" section, it is stated that all prices
should be in USD in your proposal. During the meeting this day, it has
been mentioned it would be important to add a date for currency
conversion. For instance USD January 1st. Currency values sometimes
change rapidly and in important proportions (e.g. $CA ;-) ). As budgets
are often performed in local currency, conversion in USD should be
performed on the same reference value to allow objective comparison.
4) In point 3.c) of the requirements, I would be more precise by
specifying "... work and relations with OSGeo (especially with
conference committee, board and visibility committee)?"
5) In point 5 or 6 of the requirements, I would add an item about
available working and meeting facilities (rooms for small business
meeting, rooms with tables and power supply facilities in order to be
able to work with laptops during the conference, ...), number of rooms,
number of places per room, pricing, available options (e.g. video
projectors) and prices.
Hoping it helps.
Best regards,
Th.
Prof. Thierry Badard, Ph.D.
____________________________________________________________
Professeur au Département des sciences géomatiques
(http://www.scg.ulaval.ca)
Chercheur régulier au Centre de Recherche en Géomatique
(http://www.crg.ulaval.ca)
Chercheur régulier du Réseau de Centres d'Excellence GEOIDE
(http://www.geoide.ulaval.ca)
Chercheur collaborateur de la chaire de recherche
industrielle en base de données géospatiales décisionnelles
(http://mdspatialdb.chair.scg.ulaval.ca)
Responsable du projet de formation sur les normes
internationales en géomatique
(http://sirs.scg.ulaval.ca/YvanBedard/formation_ISO.asp)
Administrateur du projet open source GeOxygene
(http://oxygene-project.sourceforge.net)
Faculté de foresterie et de géomatique
Pavillon Louis-Jacques Casault
1055, avenue du Séminaire
Local 1343
Université Laval
Québec (Québec) G1V 0A6
Canada
Tél.: (418) 656-7116 - Fax: (418) 656-7411
Courriel : Thierry.Badard at scg.ulaval.ca
Web: http://geosoa.scg.ulaval.ca
*AVERTISSEMENT*
Avis relatif à la confidentialité
Notice of confidentiality
Advertencia de confidencialidad
http://www.rec.ulaval.ca/lce/securite/confidentialite.htm
More information about the Conference_dev mailing list
