[OSGeo-Conf] Survey re: deciding factors
Claude Philipona claude.philipona at camptocamp.com
Wed Jul 9 06:08:14 EDT 2008
Hello,
For the Events question: the question is a little bit confusing: mix of
international events and regional/local events. The first question
should stick the the global event (Foss4g)
Another question should be added for regional/language event for fossgis
(german), event in france, brazil,...
Claude
Tyler Mitchell (OSGeo) wrote:
> A while back the idea of hosting a survey came up.  With Jeff's help I
> have put a survey online with the following variable/choices.  I can
> make this available to general public feedback if the group is
> interested.  Cameron - I believe you were showing interest in having
> results from such a survey for 2009 planning.
> What do you guys think?  Anything to change/add?
> Tyler
> Please check the events below that you have attended in the past or plan
> to attend in the future.
> Past Events:
>  FOSS4G 2007 - Canada
>  FOSSGIS 2007 - Germany
>  FOSS4G 2006 - Switzerland
>  FOSSGIS 2006 - Germany
>  OSG 2005 - USA
>  OSGIS 2004 - Canada
>  FOSS/GRASS 2004 - Thailand
> Future Events:
>  FOSS4G 2008 - South Africa
>  FOSSGIS 2008 - Germany
>  FOSS4G 2009 - Australia
>  FOSSGIS 2009 - Germany
>  FOSS4G 2010 - Yet to be determined
>  FOSSGIS 2010 - Germany
> Select the items that are most critical for whether or not you will
> attend an event:
> Deciding Factors: (required input)
>  Availability of workshops
>  Cost of event
>  Cost of workshops
>  Distance to event
>  Hosting country/travel requirements
>  Hosting location appeal
>  Program quality
>  Timing and schedule
>  Other... (leave comment below)
> Other comments:
> If you selected "Other" as a Deciding Factor, provide comment here.
> Conference_dev mailing list
> Conference_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/conference_dev
Claude Philipona
Camptocamp SA
PSE A
CH-1015 Lausanne
Switzerland
+41 21 619 10 11 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
+41 78 648 32 84 (mobile)
http://www.camptocamp.com http://www.cartoweb.org
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/conference_dev/attachments/20080709/17e20a2d/claude_philipona.vcf
More information about the Conference_dev mailing list
