[OSGeo-Conf] 2012 Final Step: Voting
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Sep 2 16:25:15 EDT 2011
On 11-09-02 5:22 PM, Frank Warmerdam wrote:
> Jeff,
> At the risk of partially disenfranchising you, I would suggest we hold
> a new vote promptly with you (as chair) refraining from voting unless
> there is a tie in which case you are the tie breaker.
> In a way it is cool that there is a tie.  We basically have two
> fairly compelling options.  We just need to come to a conclusion
> and move on.
I'm definitely fine with this.  Makes sense to me.
-jeff
More information about the Conference_dev mailing list
