[OSGeo-Conf] FOSS4G 2008 broken?
Tyler Mitchell tmitchell at osgeo.org
Sun Jan 29 18:33:53 EST 2012
I had tried to pull a static copy to run, it's definitely not worth running OCS
just for one archived site.  wget didn't do it that well for me.  If someone
else has a good solution for recursive sucking of a site, then I suggest
going with that!
Tyler
On 2012-01-29, at 1:31 PM, Frank Warmerdam wrote:
> On 12-01-29 09:46 AM, Arnulf Christl wrote:
>> Folks,
>> seems like something broke in the FOSS4G 2008 setup, the links don't
>> direct to a working copy of the conference:
>> http://foss4g.org/
>> goes to:
>> http://conference.osgeo.org/index.php/foss4g/2008
>> http://2008.foss4g.org/
>> goes to:
>> http://conference.osgeo.org/index.php/foss4g/foss4g2008
> Arnulf,
> I looked into this briefly.  The 2008 web site was managed using OCS.
> OCS is currently living on the webextra VM.  I'm not who migrated it
> there from osgeo1, but to the best I can understand it is not working
> properly and I don't know why.
> I gather the data for the conference live in mysql.
> OK, after some more fiddling I found that one of the .php files in
> /osgeo/ocs2/ocs-2.1.1-2/cache appeared to be truncated.  Under the
> assumption items in a directory called cache were recreateable I
> erased all the .php files in this directory.  Magically everything worked
> after that.
> I'm not sure how things got into this state, but it is working now.
> It is my personal opinion that depending on a running instance of
> OCS for the 2008 site is very fragile and it would be nice if we could
> somehow extract a static web site for that conference with all the
> valuable materials.
> However, that isn't something I really want to take on.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://home.gdal.org/warmerda
> and watch the world go round - Rush    | Geospatial Software Developer
> Conference_dev mailing list
> Conference_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/conference_dev
More information about the Conference_dev mailing list
