[OSGeo-Conf] Conference Committee members
Jeroen Ticheler jeroen.ticheler at geocat.net
Wed Jun 24 23:44:47 PDT 2015
Same here, but I object to having this type of review so often. Last time a cleanup was done was, as far as I remember, less than a year ago (maybe half a year).
Cheers,
Jeroen
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer, MapServer, PostGIS and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
Tel: +31 (0)6 81286572
http://geocat.net
> Op 25 jun. 2015 om 08:21 heeft Venkatesh Raghavan <venka.osgeo at gmail.com> het volgende geschreven:
>> On 2015/06/25 14:23, Peter Batty wrote:
>> I would like to continue on the conference committee.
> Same here.
> Venka
>> Cheers,
>>     Peter.
>>> On Jun 25, 2015, at 12:05 AM, Cameron Shorter <cameron.shorter at gmail.com> wrote:
>>> Hi Eli/Conference list,
>>> I suggest that if you are reading this email, and would like to continue to be on the conference email list, then you respond to Eli's email (within 1 week) to confirm this.
>>> Eli will then be able to determine who is active, and remove the remainder to "Past Member" status.
>>> Eli, I'm happy to remain on the list of active conference committee members.
>>> Cheers, Cameron.
>>>> On 24/06/2015 3:40 pm, Eli Adam wrote:
>>>> Hi Committee,
>>>> We are approaching "feature freeze" for committee membership changes.
>>>> Please review the current list to see if it is correct [0].
>>>> Thanks, Eli
>>>> [0] http://wiki.osgeo.org/wiki/Conference_Committee
>>>> _______________________________________________
>>>> Conference_dev mailing list
>>>> Conference_dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/conference_dev
>>> Cameron Shorter,
>>> Software and Data Solutions Manager
>>> LISAsoft
>>> Suite 112, Jones Bay Wharf,
>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
More information about the Conference_dev mailing list
