[OSGeo-Discuss] Integration test bed thingy at FOSS4G
Daniel Morissette dmorissette at mapgears.com
Fri Aug 24 14:58:44 PDT 2007
Justin Deoliveira wrote:
> I have a mapserver instance installed on the same server running the
> postgis database. I am using it to publish some raster data via WMS at
> the moment. Probably use it to serve up some dem data as well.
A MapServer WMS is probably, just like the database itself, one of the
backend services that should be hosted on the main server and have its
URL published as early as possible so that others can build their demos
against it.
> But we can definitely keep it running in order to participate in the
> showcase. A volunteer (more experienced with mapserver then myself :) )
> to help setup some nice map files would be welcomed.
Which version of MapServer are you currently running, probably 4.10?
Would it be an option to also install a recent 5.0 beta with AGG support
(with some help)?
Hopefully we can make that a MapServer community effort and if Paul (who
just replied saying he'd also be interested) and/or myself setup a
strawman mapfile others from the community can contribute enhancements
to it to make the default map output (without SLD) look real good.
This is probably becoming off-topic for this list, is there another
better place where we could continue that discussion with interested
parties?
Daniel
Daniel Morissette
http://www.mapgears.com/
More information about the Discuss mailing list
