[OSGeo-Discuss] Computing area using different Spatial Refences
Eduardo Patto Kanegae eduardo.kanegae at inflor.com.br
Thu May 31 05:38:21 PDT 2007
Hi folks,
A cartographic doubt:
We have a WGS 84 dataset ( EPSG:4326 ) and the need to to calculate
(in hectares) the area of each polygon. To do this, we are currently
transforming
these objects for our local common UTM spatial reference ( SAD69,
EPSG:29183 ) .
But, I was thinking if maybe the most correct procedure is to transform
objects
to UTM WGS84 and then calculate area.
Is this right? Does "GCS-WGS84 to UTM-WGS84" provides LESS distortion
than "GCS-WGS84 to UTM-SAD69" ?
For a given geometry(described at the end of message), we calculated
values using "to UTM WGS84" and "to UTM SAD69"
and have different values.
- Hectares using Transform(...,29183) = 30,9977784638335
- Hectares using Transform(...,32723) = 30,997559727974
Note: I made this test using MsSqlSpatial (
http://www.codeplex.com/MsSqlSpatial )
which implements Transform functions using NTS engine( a C# GEOS fork)
best regards
INFLOR Consultoria e Sistemas Ltda.
Consultor GIS
Tel: +55(27)2122-0888
Cel: +55(27)8155-2990
Fax: +55(27)2122-0861
eduardo.kanegae at inflor.com.br <mailto:eduardo.kanegae at inflor.com.br>
www.inflor.com.br <http://www.inflor.com.br>
Geometry = MULTIPOLYGON(((-45.7299999825502
-23.4137918719708,-45.7298474592665 -23.4141643443615,-45.7299640178008
-23.4144445857606,-45.7302059333606 -23.4147448895108,-45.7305392178703
-23.4151129871136,-45.7304648831737 -23.4154146692545,-45.7301019968213
-23.4154857186816,-45.7297770575147 -23.4156564197187,-45.7295406062637
-23.4159345587639,-45.7295180183446 -23.4160432063777,-45.7297152445053
-23.4159895899592,-45.7300259907199 -23.4159282449557,-45.7300972091581
-23.4162133526445,-45.7300151901629 -23.4165159427538,-45.7301851979433
-23.4168124195482,-45.7301907149713 -23.4168153656499,-45.7301935896905
-23.4168137209514,-45.7301965242754 -23.4168121688986,-45.7301995152201
-23.4168107113444,-45.7302025589457 -23.4168093500392,-45.730205651829
-23.4168080865958,-45.7302087901694 -23.4168069225334,-45.7302119702216
-23.4168058592376,-45.7302151881819 -23.4168048979746,-45.7302184402123
-23.4168040399031,-45.7302217224305 -23.4168032860351,-45.7302250309148
-23.4168026372805,-45.7302283617139 -23.4168020944065,-45.7302317108518
-23.4168016580691,-45.7302350743227 -23.4168013287862,-45.73023844812
-23.4168011069508,-45.7302418282028 -23.4168009928271,-45.7302452105438
-23.4168009865497,-45.7302485911006 -23.4168010881286,-45.73025196583
-23.4168012974445,-45.7302553307124 -23.4168016142445,-45.7302586817226
-23.4168020381505,-45.7302620148587 -23.4168025686598,-45.7302653261425
-23.4168032051315,-45.7302686116191 -23.4168039468128,-45.7302718673668
-23.4168047928129,-45.7302750894919 -23.4168057421203,-45.7302782741488
-23.4168067936077,-45.7302814175344 -23.4168079460181,-45.7302845158981
-23.4168091979694,-45.7302875655322 -23.4168105479725,-45.7302905628006
-23.4168119944131,-45.7302935041248 -23.4168135355652,-45.7302963859882
-23.4168151695824,-45.7302992049511 -23.4168168945193,-45.7303019576456
-23.4168187083149,-45.7303046407851 -23.416820608805,-45.7303072511647
-23.4168225937136,-45.7303097856709 -23.4168246606752,-45.7303122412714
-23.4168268072169,-45.730314615035 -23.4168290307808,-45.7303169041267
-23.4168313287103,-45.7303191058122 -23.416833698259,-45.7304379671023
-23.4167779519871,-45.7307344444205 -23.4166926298826,-45.7309434023949
-23.4166929173927,-45.7311160295787 -23.4167235750228,-45.7313439698155
-23.416755782876,-45.7315522191724 -23.4167866097821,-45.7317511252108
-23.416823864995,-45.7318541828355 -23.4168340898585,-45.7318569804873
-23.4168322716779,-45.7318598452966 -23.4168305448603,-45.7318627737637
-23.4168289115082,-45.7318657623111 -23.4168273736259,-45.7318688072834
-23.416825933085,-45.7318719049569 -23.4168245916498,-45.7318750515494
-23.4168233509651,-45.7318782432101 -23.4168222125419,-45.7318814760445
-23.4168211777669,-45.7318847460991 -23.4168202479155,-45.7318880493714
-23.4168194241206,-45.7318913818342 -23.4168187073817,-45.7318947394065
-23.4168180985872,-45.7318981179869 -23.4168175984691,-45.7319015134448
-23.4168172076488,-45.7319049216291 -23.4168169265957,-45.7319083383833
-23.4168167556591,-45.7319117595166 -23.416816695046,-45.7319151808611
-23.4168167448292,-45.7319185982244 -23.4168169049484,-45.7319220074374
-23.4168171752133,-45.7319254043254 -23.4168175552827,-45.7319287847467
-23.4168180447034,-45.7319321445591 -23.4168186428665,-45.7319354796678
-23.4168193490512,-45.731938785982 -23.4168201623854,-45.7319420594732
-23.4168210818849,-45.7319452961361 -23.4168221064143,-45.7319484920084
-23.4168232347305,-45.7319516431946 -23.4168244654482,-45.731954745837
-23.4168257970698,-45.7319577961452 -23.4168272279596,-45.7319607903857
-23.4168287563745,-45.7319637249067 -23.4168303804463,-45.7319665961184
-23.4168320981905,-45.7319694005126 -23.416833907502,-45.7321449216411
-23.4167615995725,-45.7324720142104 -23.4166279226002,-45.7327663919823
-23.4164185025253,-45.7327112622679 -23.4161233455381,-45.7326945401911
-23.4157392625233,-45.7325332597829 -23.4154151781557,-45.7323429178001
-23.4150656045789,-45.7323534510707 -23.4147068119265,-45.7324513737155
-23.4145139189808,-45.7324632872318 -23.4144994230444,-45.7325953283848
-23.4144012371142,-45.7329474445403 -23.4142379753559,-45.73338204598
-23.4140866058128,-45.7337925523976 -23.4139941902245,-45.7341605318968
-23.4141337943951,-45.7344940122029 -23.4142285987434,-45.7348447308416
-23.4141115720808,-45.7351720754738 -23.4140365150517,-45.7348337098048
-23.4140070494563,-45.7344984146517 -23.4140508426611,-45.7342561565566
-23.4138495121069,-45.7339470249825 -23.4136227426457,-45.7335660253042
-23.4135424306951,-45.733160793441 -23.4134815888767,-45.7327804465898
-23.4133292729273,-45.7323817660233 -23.4132223180433,-45.7320234219836
-23.4130525496583,-45.7316704842359 -23.412957651178,-45.7313163083275
-23.4128805778458,-45.7310032831278 -23.4128189155444,-45.7307281590562
-23.4128404631505,-45.7306291308941 -23.4128637103565,-45.7304095374677
-23.4131081402914,-45.7302045499072 -23.4134277558153,-45.7299999825502
-23.4137918719708)),((-45.7291782195107
-23.4162592067941,-45.7294258716944 -23.416287817404,-45.729426062044
-23.4162586868925,-45.729450288511 -23.4161519836841,-45.7294490075517
-23.4161509558313,-45.7294477659938 -23.4161498875961,-45.7294465653223
-23.4161487802686,-45.7294454069934 -23.4161476351789,-45.729444292391
-23.4161464537026,-45.7294432228608 -23.4161452372638,-45.7294421996908
-23.4161439873276,-45.7294412241062 -23.4161427053945,-45.729440297289
-23.4161413930103,-45.7294394203444 -23.4161400517519,-45.729438594334
-23.4161386832324,-45.7294378202521 -23.4161372891007,-45.7294370990255
-23.4161358710283,-45.7294364315281 -23.4161344307317,-45.7294358185615
-23.4161329699319,-45.7294352608549 -23.416131490395,-45.7294347590894
-23.4161299939006,-45.7294343138641 -23.4161284822422,-45.7294339257203
-23.4161269572491,-45.7294335951123 -23.4161254207465,-45.7294333224511
-23.4161238745867,-45.7294331080609 -23.4161223206358,-45.7294329521934
-23.4161207607512,-45.7294328550472 -23.4161191968216,-45.7294328167293
-23.4161176307186,-45.7294328372885 -23.4161160643363,-45.7294329167015
-23.4161144995511,-45.7294330548723 -23.4161129382489,-45.7294332516374
-23.4161113823069,-45.7294335067557 -23.4161098336025,-45.7294338199189
-23.4161082939915,-45.7294341907555 -23.4161067653342,-45.7294346188167
-23.4161052494599,-45.7294351035911 -23.4161037482031,-45.7294356444895
-23.4161022633626,-45.7294362408649 -23.4161007967243,-45.7294368919978
-23.416099350061,-45.7294375971055 -23.4160979251058,-45.7294383553379
-23.416096523574,-45.7294391657865 -23.4160951471548,-45.729440027475
-23.4160937974974,-45.7294409393646 -23.4160924762379,-45.7294419003577
-23.4160911849546,-45.7294429093038 -23.4160899252088,-45.7294439649845
-23.4160886985079,-45.7294450661279 -23.4160875063376,-45.7294462114139
-23.4160863501261,-45.7294473994591 -23.4160852312658,-45.7294486288411
-23.4160841511005,-45.7294498980749 -23.4160831109343,-45.7294512056315
-23.4160821120176,-45.7294525499477 -23.416081155548,-45.7294539293975
-23.4160802426828,-45.7294553423205 -23.416079374513,-45.7294567870226
-23.4160785520894,-45.7294582617608 -23.4160777764007,-45.7294597647676
-23.4160770483777,-45.7294612942272 -23.416076368898,-45.7294947812988
-23.4159152967919,-45.7297444910363 -23.4156215618097,-45.7300843987332
-23.4154429974222,-45.7304241054579 -23.4153764863751,-45.7304861256583
-23.4151247821174,-45.7301674897108 -23.4147728630167,-45.7299207380751
-23.4144665558545,-45.7297950938979 -23.4141644695852,-45.7299552192783
-23.4137734327281,-45.7301617381991 -23.4134058431355,-45.730369396055
-23.4130820642585,-45.7306003082475 -23.4128250354443,-45.7309017859032
-23.4126780870865,-45.7312834597895 -23.4126307671851,-45.7316878909204
-23.4126254522627,-45.732071323409 -23.4125395115093,-45.7321887329994
-23.4124692904379,-45.7320924145934 -23.4124224997134,-45.7317752654633
-23.4123732980333,-45.7313094638034 -23.4123396998385,-45.7305015635307
-23.4124239826242,-45.7302641561242 -23.412515778272,-45.7300096229375
-23.4126651245672,-45.7298440593929 -23.4128193459128,-45.7296076390376
-23.4131326375676,-45.7292985996475 -23.4136826515491,-45.7291589225407
-23.4139874223842,-45.7290730773607 -23.414195024758,-45.7289520775469
-23.4145780964343,-45.7288213642249 -23.4147862848023,-45.72868421886
-23.4149945032925,-45.7286157981141 -23.4151867652827,-45.7285763650547
-23.4154042099316,-45.7284595642114 -23.415588302279,-45.728407226277
-23.4156747014181,-45.7284074723667 -23.415719650806,-45.7284118832462
-23.4157833101871,-45.7284120678153 -23.4158170221673,-45.7284082721616
-23.4158657361478,-45.7283318476437 -23.416004689826,-45.728331970677
-23.416027164408,-45.7283362174878 -23.4160608574485,-45.7283647972728
-23.416086945325,-45.7284995090207 -23.4162061851154,-45.7285687525277
-23.4162395750364,-45.7286012711474 -23.4162431693434,-45.7289466277054
-23.4162527959056,-45.7291782195107
-23.4162592067941)),((-45.7336267275866
-23.4126788457351,-45.7334114826005 -23.4127789843516,-45.7332185516777
-23.4125770636617,-45.7329482102613 -23.4124825787353,-45.7326045633301
-23.4124669240912,-45.7323584974651 -23.4124387858074,-45.7323264294667
-23.4124460458805,-45.7323068017133 -23.4124524911196,-45.7320909561692
-23.4125815855156,-45.7316940913275 -23.4126705369464,-45.7312870788104
-23.4126758858055,-45.7309169362381 -23.4127217760656,-45.7307737510437
-23.4127915685045,-45.7310063888013 -23.4127733483674,-45.7313270327014
-23.4128365114712,-45.7316829523888 -23.4129139642747,-45.7320416054335
-23.4130103994912,-45.7323999361366 -23.4131801615618,-45.7327970830596
-23.4132867049998,-45.7331746750906 -23.4134379177502,-45.7335754121533
-23.4134980847072,-45.7339687669576 -23.4135810010195,-45.7342877851509
-23.4138150229848,-45.7345141817517 -23.4140031717131,-45.7348325639711
-23.4139615874974,-45.7352090246822 -23.4139943704628,-45.7352017082878
-23.4138401513776,-45.7351809330314 -23.4136983638426,-45.7351459065805
-23.4135492833948,-45.7350748841658 -23.413408813635,-45.7349486326937
-23.4133019673534,-45.7348266506748 -23.4132130670349,-45.7346751497899
-23.4131074156403,-45.734528987793 -23.4130125785906,-45.7343311214405
-23.4128978162824,-45.734135271707 -23.4127886002606,-45.7339504561427
-23.4126364382189,-45.7337764190477 -23.4124494768816,-45.7336543831102
-23.4122053776139,-45.7336758590329 -23.4119492000563,-45.7336009474932
-23.4121050305283,-45.7335623019592 -23.4123598699327,-45.7336267275866
-23.4126788457351)),((-45.7301443536378
-23.4083297477835,-45.7303293638306 -23.4083473668515,-45.7301948998092
-23.4082554140558,-45.729982618463 -23.4080731738074,-45.7298190432944
-23.4080144259213,-45.7298812548447 -23.4081659547384,-45.7301443536378
-23.4083297477835)),((-45.7287398071875
-23.4111181560934,-45.7288077480882 -23.4116929058853,-45.7288979414088
-23.4118941317602,-45.7290739213273 -23.4120739605955,-45.7292625783374
-23.4121467265587,-45.7295366610539 -23.4121927912505,-45.7298273676836
-23.4121493498949,-45.7304084911671 -23.4120098621187,-45.730721870946
-23.4119400107095,-45.7317262055521 -23.4119931754309,-45.7322741114468
-23.4120379526509,-45.7323141307727 -23.4120535463384,-45.732325713623
-23.4120850547865,-45.7323259452183 -23.4121271375753,-45.7323260610155
-23.4121481788627,-45.7322547916066 -23.4121956266323,-45.7324773295516
-23.4122253416248,-45.7329329892193 -23.4123031619033,-45.7332439517059
-23.4123483444874,-45.7333018312066 -23.4123613989958,-45.7333236183618
-23.4123812858618,-45.7333238386748 -23.4124212635198,-45.7333239855495
-23.4124479151401,-45.7333097175045 -23.4124812976116,-45.7332486179819
-23.4125402474029,-45.7334231956234 -23.4127229596509,-45.7335718870451
-23.4126537838103,-45.733512732482 -23.4123609047942,-45.7335534349347
-23.4120925021697,-45.7336342202646 -23.4119244531983,-45.7336637527303
-23.4118792305629,-45.733390597683 -23.4118645384929,-45.7329464941624
-23.4118518611291,-45.7325561726531 -23.4116248726302,-45.7321653965855
-23.4111922012483,-45.7321641674906 -23.4111917274211,-45.7320160680744
-23.4112419025138,-45.7317819323045 -23.4113318097307,-45.7315116724276
-23.4113977446708,-45.7312127543877 -23.4113920207153,-45.7309201976375
-23.4113817869279,-45.7306291629651 -23.411332934417,-45.7303088063952
-23.411304642549,-45.7300591295947 -23.4112315074431,-45.7300576013669
-23.411232211592,-45.7300560474442 -23.4112328660887,-45.7300544697153
-23.4112334701353,-45.7300528701032 -23.4112340229965,-45.730051250565
-23.4112345240035,-45.7300496130628 -23.4112349725365,-45.7300479595933
-23.41123536806,-45.7300462921771 -23.4112357100835,-45.7300446128406
-23.4112359981918,-45.7300429236343 -23.4112362320365,-45.730041226614
-23.4112364113319,-45.7300395238455 -23.4112365358586,-45.7300378174096
-23.4112366054645,-45.7300361093776 -23.4112366200684,-45.730034401831
-23.4112365796472,-45.7300326968564 -23.4112364842537,-45.7300309965262
-23.411236334003,-45.7300293029182 -23.4112361290768,-45.7300276180864
-23.4112358697288,-45.7300259440897 -23.4112355562746,-45.7300242829684
-23.411235189088,-45.7300226367437 -23.4112347686275,-45.7300210074226
-23.4112342953964,-45.7300193969883 -23.411233769978,-45.7300178074052
-23.4112331930052,-45.7300162406138 -23.4112325651909,-45.7300146985114
-23.4112318872883,-45.730013182991 -23.4112311601355,-45.7300116958876
-23.4112303846109,-45.7300102390177 -23.4112295616597,-45.7300088141591
-23.4112286922855,-45.7300074230418 -23.4112277775454,-45.7300060673622
-23.4112268185592,-45.7300047487785 -23.4112258164957,-45.7300034688911
-23.4112247725686,-45.7300022292619 -23.4112236880545,-45.7300010314004
-23.4112225642744,-45.7299998767628 -23.4112214025987,-45.7299987667575
-23.4112202044383,-45.7299977027447 -23.4112189712575,-45.7299966860077
-23.4112177045571,-45.7299957177961 -23.4112164058819,-45.7299947992874
-23.4112150768091,-45.7299939315963 -23.4112137189645,-45.72999311578
-23.4112123340014,-45.7299923528378 -23.4112109236042,-45.7299916436967
-23.4112094894936,-45.729990989221 -23.4112080334125,-45.729990390203
-23.4112065571403,-45.7299898473818 -23.4112050624741,-45.7299893614144
-23.4112035512382,-45.7299889328905 -23.4112020252663,-45.7299885623323
-23.4112004864234,-45.7299882501943 -23.4111989365793,-45.7299879968589
-23.4111973776309,-45.7299878026261 -23.4111958114713,-45.729987667743
-23.4111942400067,-45.7299875923651 -23.4111926651575,-45.7299875765898
-23.4111910888398,-45.7299876204374 -23.4111895129745,-45.7299877238458
-23.4111879394829,-45.7299878867001 -23.4111863702776,-45.7299881087934
-23.4111848072717,-45.7299883898608 -23.4111832523785,-45.7299887295554
-23.4111817074805,-45.7299891274674 -23.411180174465,-45.7299895831094
-23.4111786551973,-45.7299900959267 -23.4111771515342,-45.7299906652918
-23.4111756653059,-45.7299912905143 -23.4111741983164,-45.7299919708361
-23.4111727523655,-45.7299927054218 -23.4111713291997,-45.7299934933777
-23.411169930566,-45.7299943337473 -23.4111685581624,-45.7299952255014
-23.4111672136608,-45.7299961675575 -23.4111658987021,-45.7299971587654
-23.411164614887,-45.7299981979165 -23.4111633637814,-45.7299992837491
-23.4111621469065,-45.7300004149383 -23.4111609657439,-45.730001590106
-23.411159821735,-45.7300028078207 -23.4111587162772,-45.7300040665973
-23.4111576507102,-45.7300053649024 -23.411156626338,-45.7300067011541
-23.4111556444073,-45.7300080737215 -23.4111547061155,-45.7300094809399
-23.4111538126026,-45.7300109210913 -23.4111529649553,-45.7300123924185
-23.4111521642158,-45.7300138931254 -23.4111514113507,-45.7300154213963
-23.4111507072779,-45.7300169753574 -23.4111500528617,-45.7300185531197
-23.411149448891,-45.7300201527604 -23.4111488961103,-45.730021772332
-23.4111483951882,-45.7300234098626 -23.4111479467356,-45.7300250633509
-23.411147551297,-45.7300267307858 -23.4111472093583,-45.7300284101362
-23.4111469213348,-45.7300300993564 -23.4111466875748,-45.7300317963857
-23.4111465083643,-45.7300334991583 -23.4111463839223,-45.7300352056032
-23.4111463144012,-45.7300369136345 -23.4111462998865,-45.7300386211756
-23.4111463403923,-45.7300403261447 -23.4111464358705,-45.7300420264597
-23.4111465862059,-45.7300437200573 -23.4111467912166,-45.7300454048741
-23.4111470506537,-45.7300470788508 -23.4111473641925,-45.7300487399474
-23.4111477314593,-45.7300503861474 -23.4111481520043,-45.7300520154391
-23.41114862532,-45.730053625839 -23.4111491508184,-45.7300552153879
-23.4111497278668,-45.7300567821451 -23.4111503557656,-45.7300583242037
-23.4111510337393,-45.7300598396853 -23.4111517609722,-45.7300613267401
-23.4111525365724,-45.7300627835615 -23.4111533595946,-45.7300642083669
-23.4111542290399,-45.7300655994311 -23.4111551438465,-45.7300669550479
-23.4111561028995,-45.7300682735738 -23.4111571050341,-45.7300695534035
-23.4111581490232,-45.73007079297 -23.4111592335996,-45.7300719907643
-23.4111603574374,-45.7300731453298 -23.4111615191753,-45.7300742552631
-23.411162717389,-45.7300753192088 -23.411163950623,-45.7300763358643
-23.4111652173724,-45.7300773039993 -23.4111665160964,-45.7300782224363
-23.4111678452137,-45.7300790900461 -23.4111692031027,-45.7300799057811
-23.4111705881059,-45.7300806686373 -23.4111719985431,-45.7300813776972
-23.4111734326895,-45.7300820320869 -23.4111748888017,-45.730082631019
-23.4111763651007,-45.7300831737544 -23.4111778597937,-45.7300836596311
-23.4111793710564,-45.7300840880691 -23.4111808970507,-45.7300844585319
-23.4111824359118,-45.7300847705792 -23.4111839857694,-45.730085023829
-23.4111855447313,-45.7300852179664 -23.4111871109047,-45.7300853527588
-23.4111886823696,-45.7300854280413 -23.4111902572236,-45.730085443726
-23.4111918335417,-45.7303186492624 -23.4112601438953,-45.7306358841335
-23.4112881600667,-45.7309255296673 -23.4113367794084,-45.7312141888062
-23.4113468768614,-45.7315058132373 -23.4113524611555,-45.7317662071715
-23.4112889332011,-45.7319982287483 -23.4111998378235,-45.7320977472223
-23.4111661216525,-45.7316810405757 -23.4110054756209,-45.7312855134908
-23.4108042292962,-45.7311563061129 -23.4104744702937,-45.7312182984581
-23.4099888741752,-45.7312688463835 -23.4093689587842,-45.7310809872195
-23.4088440457497,-45.730725312915 -23.4085099710867,-45.7303761129111
-23.4083972202951,-45.730127144784 -23.4083735103563,-45.7298410032348
-23.4081953719467,-45.7297343266628 -23.4079355391867,-45.7297021352244
-23.4079303419063,-45.729658702969 -23.4080751377234,-45.7295945217415
-23.408206645174,-45.7296274627529 -23.4082269464782,-45.7296370233624
-23.4082443584431,-45.7296497228495 -23.4082588462075,-45.7296502013366
-23.4083461261119,-45.7296028074032 -23.4085497272239,-45.7295438338532
-23.4087268903319,-45.7294807223736 -23.4088782764617,-45.7293218020983
-23.4090485355623,-45.7290907679494 -23.4091859647,-45.7290749038954
-23.40920814975,-45.7290750048317 -23.4092265750571,-45.7290954704903
-23.4093149234393,-45.7290958540611 -23.4093849395236,-45.7290920397822
-23.4094181238584,-45.7290366372589 -23.4095178815275,-45.7289426075154
-23.4096982139127,-45.7287138744532 -23.4108195409717,-45.7287398071875
-23.4111181560934)))
More information about the Discuss mailing list
