[OSGeo-Discuss] Drawing on the map based on coordinates
Landon Blake lblake at ksninc.com
Mon Apr 7 12:52:04 EDT 2008
Justin,
I'm not a Mapguide user, but I think the mailing list I posted
previously is the one that you want.
Landon
-----Original Message-----
[mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Justin Driskell
Sent: Monday, April 07, 2008 9:09 AM
To: OSGeo Discussions
Subject: RE: [OSGeo-Discuss] Drawing on the map based on coordinates
Ok let me check to make sure I understand and forgive my mistake.  I am
writing a function that will be used by my website (in CS) to grab
coordinates of sites from a database.  Then using the Mapguide API I
will plot on the map those sites.  I need to go else where for this
answer?  Can you direct me to where I can get Mapguide API help.  I
already have the Mapguide API documentation but I need a little help
getting to the right function to do the job.  Does Mapguide have a
function like drawCircle(location, layer).
Justin Driskell
Engineer 1
(770)-989-9488
jdriskel at scires.com
Scientific Research Corporation
2300 Windy Ridge Parkway
Suite 400 South
Atlanta, GA 30339
770-859-9161 (phone)
770-859-9315 (fax)
>>> "Landon Blake" <lblake at ksninc.com> 4/7/2008 11:19 AM >>>
Justin,
This is the discussion list for the OSGeo, a non-profit organization
that supports open source GIS software development. It is not the user
list for Mapguide. (This is a common mistake.)
If you want an answer to your question you should find and post to the
Mapguide user list.
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Landon
Sent: Monday, April 07, 2008 6:11 AM
To: discuss at lists.osgeo.org
Subject: [OSGeo-Discuss] Drawing on the map based on coordinates
Hello I am new to mapguide.  I am using Mapguide 1.2 and IIS/Dot. I need
to be able to draw shapes on the mapguide map from coordinates.  I was
looking at the sample webpage buffer task.   I can see how shapes are
drawn but I have not found how it gets its location where to draw.  The
example uses a click to get a feature and draws around it.  I need to
take Coordinates pulled from a database and draw the shape at that
location.  Any help pointing me in the direction of how to use
coordinates instead of mouse clicks to that buffer task example would be
appreciated.
Thanks in advanced
Justin Driskell
Engineer 1
(770)-989-9488
Suite 400 South
Atlanta, GA 30339
770-859-9315 (fax)
Discuss mailing list
Discuss at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/discuss
Warning:
Information provided via electronic media is not guaranteed against
defects including translation and transmission errors. If the reader is
not the intended recipient, you are hereby notified that any
dissemination, distribution or copying of this communication is strictly
prohibited. If you have received this information in error, please
notify the sender immediately.
More information about the Discuss mailing list
