[OSGeo-Discuss] Error OGR Driver in Studio 2009
Mon Apr 7 12:50:29 PDT 2008
Marcel Santos Silva wrote:
> Hello,
> I am using Mapguide Open Source 2.0, Studio 2009, FDO 3.3.1 (OGR Driver
> to Oracle Spatial) and Windows XP SP2. I try to connect in the Studio
> and a error is reported:
> An exception occurred in FDO component.
> Connect failed:
> In Error.log:
> <2008-04-07T15:16:50>             Administrator
>  Error: An exception occurred in FDO component.
>         Connect failed:
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpTestFeatureSourceConnection.Execute line 100 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
>   - MgFdoConnectionManager.Open line 858 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> Connect failed:
Marcel,
This is definately not the most focused place to take this question.
I would suggest either the MapGuide or FDO mailing lists. I might suggest
the gdal-dev mailing list (OGR is part of GDAL), except that so far there
isn't any information indicating that things are actually getting down into
OGR.
I will note that I don't believe Oracle Spatial support is built into
the default OGR provider binaries distributed by the MapGuide and FDO
teams.  Perhaps that is your problem?  You might want to first test
out accessing something simple, like a shapefile, through the OGR
provider and once that is working try Oracle Spatial.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the Discuss mailing list
