[OSGeo-Discuss] GPRS connection API
dorra labidi dorrdor at yahoo.fr
Fri Apr 11 02:01:24 PDT 2008
    There is a major difference between serial port connection and GPRS connection: The GPRS connection involves the APN as connection parameter in addition to the port name and the ip address...
"Tyler Mitchell (OSGeo)" <tmitchell at osgeo.org> a écrit : On 11-Apr-08, at 12:38 AM, dorra labidi wrote:
> Hello all;
> I am developping a fleet management application using java. I need
> to connect to the GPS box using GPRS network.
> My question: Is there a java API for the GPRS connection?
> Thank you in advance...
 From what I've seen, some embedded GPRS platforms provide a simple
serial port connection to the operating system so that GPRS
connections themselves aren't any different than other modems.  I
don't really know Java, but perhaps depending on your needs and
platforms, all you might need is the Java Communications API.
Tyler
Discuss mailing list
Discuss at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/discuss
 Envoyé avec Yahoo! Mail.
Une boite mail plus intelligente.
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20080411/019189a0/attachment-0002.html>
More information about the Discuss mailing list
