[OSGeo-Discuss] project management software (foss) for GIS projects
Alex Mandel tech_dev at wildintellect.com
Mon Aug 4 19:35:49 PDT 2008
Ah, if you could describe more the features you're looking for in the
system I think it would help to narrow down the suggestions. Trac could
work but because of it's close ties to svn might not be the best system.
There are many other options out there depending on your needs, for
instance many of the osgeo projects and sites use Drupal, and MediaWiki.
I happen to also be a Plone developer and I think many of the available
Content Management systems have potential. Depending on how you want to
manage your datasets, take a look at the Geonetwork project on osgeo
http://www.osgeo.org/geonetwork
Even if it only does a fraction of what you need you can integrate it
with another CMS or Wiki.
Ale
maning sambale wrote:
> Alex,
> Thank you for your reply.  The versioning for postgis seems a good one.
> However, what I'm looking for is a general purpose PMS for planning,
> coordinating GIS projects.
> I'll try postgis versioning though.  Thanks!
> maning
> On Tue, Aug 5, 2008 at 9:44 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>> Hi,
>>> I'm looking for a FOSS PMS for managing GIS projects.  Are there any
>>> you can recommend?  I'm looking at trac, it's primarily for managinf
>>> software projects.  Is there anybody here who have used it for
>>> managing GIS projects?
>>> cheers,
>>> maning
>> Trac/svn really isn't a good option since it would keep copies of every
>> version of the binary. Poking around a little I found something based on
>>  versioning of Postgis data.
>> http://docs.codehaus.org/display/GEOTOOLS/Versioning+Postgis
>> Maybe that's more what you're looking for, it would track individual record
>> changes within your spatial layers.
>> Alex
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss mailing list
