[OSGeo-Discuss] Does Open Source need a supervisory government body?
Cameron Shorter cameron.shorter at gmail.com
Sun Jan 27 02:52:04 PST 2008
Software quality is a difficult concept to measure so that it can be
factored into purchasing decisions and budgets. How do you compare the
quality of two different projects?
I assume the authors of the paper you are reviewing are drawing upon
Quality processes like ISO 9001, or Quality Control and Quality
Assurance processes defined in CMMI, or in Mil Std 498, or ISO 12207 or
DO-178B.  (Mmm, I must get a life. Working for defense companies ensures
you get to read very some boring documents).
Government purchaser's not only need quality software, but they need to
to measure the quality of the software and determine whether it is fit
for purpose.
What is the probability the software won't work, or won't work to spec?
What is the impact if the software crashes? Will someone be killed, or
will a lot of money be lost?
The way large software vendors prove their software quality is they
define software development processes (which includes testing), then
follow the defined processes, then audit the company to ensure the
processes are followed.
This is an effective, well tested way to verify quality - and you will
find most established Open Source projects will follow do the same, to a
greater or lesser degree.
So my recommendation for a government evaluating software is:
1. Specify the need for the software.
2. Specify the criticality of the software.
3. Based on the criticality, determine the level of quality required.
4. Based on quality requirement, determine the level of processes and
testing required.
5. Verify the project in question has the required software development
processes.
6. Potentially offer resources to improve project processes.
I could bore you with hours more on this subject, but better stop here.
PS. Bruce, are you allowed to tell us Australians what report you are
responding to, and can I see a copy of it?
Bruce.Bannerman at dpi.vic.gov.au wrote:
> IMO:
> Thanks Ivan,
> Agreed.
> While government can certainly incubate, sponsor and contribute to
> projects. My personal opinion is that they are better run by 'the
> community'.
> If the project is good enough, it should get sufficient supporters and
> hopefully be picked up by a 'central authority' like OSGeo.
> Bruce
> > That sounds like removing the "F" from FOSS or should I say, that is a
> > bazaar inside a cathedral. :)
> > Seriously now, IMHO, as an FOSS contributor and a commercial software
> > developer that uses FOSS, I believe that there is a complicated process
> > of getting to the point to embrace a FOSS initiative and that statement
> > does not help it at all. Where are the decisions made, in public
> > e-mail-lists or in a cabinet? What about election and cabinet change?
> > I am not saying that a government agency can't be the incubator of a
> > *F*OSS, there are numerous successful example out there, but the
> > governance of the project matter a lot. "If you love your OSS project
> > set it free".
> Notice:
> This email and any attachments may contain information that is
> personal, confidential,
> legally privileged and/or copyright. No part of it should be
> reproduced, adapted or communicated without the prior written consent
> of the copyright owner.
> It is the responsibility of the recipient to check for and remove viruses.
> If you have received this email in error, please notify the sender by
> return email, delete it from your system and destroy any copies. You
> are not authorised to use, communicate or rely on the information
> contained in this email.
> Please consider the environment before printing this email.
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
More information about the Discuss mailing list
