[OSGeo-Discuss] Error compiling FDO 3.3.0
Jack Lee jack.lee at autodesk.com
Tue May 27 05:16:27 PDT 2008
In Ubuntu, /bin/sh has been changed from bash to dash. The scripts does not work under  the dash shell.
Verify that bash exists on your system.
If bash exist on your system, check the section on FDO Install in the following:
http://wiki.osgeo.org/wiki/Building_Mapguide_on_Ubuntu_7.04_Server
From: discuss-bounces at lists.osgeo.org [mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Gianfranco Imbrogno
Sent: Tuesday, May 27, 2008 8:06 AM
To: OSGeo Discussions
Subject: Re: [OSGeo-Discuss] Error compiling FDO 3.3.0
Yes I am running kubuntu...
Are there known problems around this distro and fdo?
2008/5/27 Jack Lee <jack.lee at autodesk.com<mailto:jack.lee at autodesk.com>>:
The script runs under the bash shell.
Are you running a version of Linux that is not using the bash shell (like Ubuntu)?
From: discuss-bounces at lists.osgeo.org<mailto:discuss-bounces at lists.osgeo.org> [mailto:discuss-bounces at lists.osgeo.org<mailto:discuss-bounces at lists.osgeo.org>] On Behalf Of Gianfranco Imbrogno
Sent: Tuesday, May 27, 2008 7:07 AM
Thanks...
I tried to run the command and I have this resoult:
test: 197: ==: unexpected operator
test: 200: ==: unexpected operator
test: 203: ==: unexpected operator
test: 259: ==: unexpected operator
test: 276: ==: unexpected operator
test: 296: ==: unexpected operator
test: 334: ==: unexpected operator
test: 354: ==: unexpected operator
test: 363: ==: unexpected operator
test: 372: ==: unexpected operator
test: 381: ==: unexpected operator
test: 390: ==: unexpected operator
test: 399: ==: unexpected operator
test: 408: ==: unexpected operator
test: 417: ==: unexpected operator
test: 426: ==: unexpected operator
test: 435: ==: unexpected operator
test: 444: ==: unexpected operator
Is it normal?
You should run the build_linux.sh script instead of the configure script directly.
Sent: Tuesday, May 27, 2008 6:36 AM
To: discuss at lists.osgeo.org<mailto:discuss at lists.osgeo.org>
Subject: [OSGeo-Discuss] Error compiling FDO 3.3.0
hello, I'm a new user of MapGuide and I've some problems building the FDO 3.3.0.<http://3.3.0.>
After executing the ./configure there is  an error "error: cannot find input file: Makefile.in"
Where is the problem?
Discuss mailing list
Discuss at lists.osgeo.org<mailto:Discuss at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/discuss
Gianfranco Imbrogno
Gianfranco Imbrogno
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20080527/63a1d0d5/attachment-0002.html>
More information about the Discuss mailing list
