[OSGeo-Discuss] Open Source development metrics
Bruce.Bannerman at dpi.vic.gov.au Bruce.Bannerman at dpi.vic.gov.au
Wed May 28 02:47:06 PDT 2008
IMO:
Thanks for the comments Puneet,
> Actually, a variation on the above may be the best metric -- "create
> feature X that we need in our organization and that works for us."
> That would allow your organization to determine what is meaningful for
> your organization first and for open source second. In other words,
> you would treat open source development no different from non-open
> source development. Open source would simply become a "normal"
> activity.
> Once feature X works for you, you could consider "donating" it to the
> open source community by whatever process that particular open source
> project has.
> Other metrics such as SLOC (source lines of code) or "feature in SVN
> trunk" are not only subject to abuse, they are also mostly
> meaningless.
We want to avoid anything that could result in an isolated fork or branch.
This is a danger with this approach.
However, it has merit in that it would allow a developer to meet their
performance
criteria and concentrate on getting the customisation into the trunk in
their
own time.
Bruce
Notice:
This email and any attachments may contain information that is personal,
confidential, legally privileged and/or copyright.No part of it should be reproduced,
adapted or communicated without the prior written consent of the copyright owner.
It is the responsibility of the recipient to check for and remove viruses.
If you have received this email in error, please notify the sender by return email, delete
it from your system and destroy any copies. You are not authorised to use, communicate or rely on the information
contained in this email.
Please consider the environment before printing this email.
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20080528/eb59bed2/attachment-0002.html>
More information about the Discuss mailing list
