[OSGeo-Discuss] methods for programatically adding fields toshapefiles
Fawcett, David David.Fawcett at state.mn.us
Thu Oct 30 09:23:43 EDT 2008
Tyler,
Here is a link to some python code that I wrote to read a delimited text
file and write out a shapefile.  It uses the ogr and osr python modules.
The code is not particularly clean or efficient, but it does include the
case of creating a shapefile, creating columns, and populating the
columns.
http://code.google.com/p/flatlandmaps/source/browse/trunk/csv2shp.py
You can email me directly if you have any questions about how it works.
David.
-----Original Message-----
[mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Tyler Erickson
Sent: Wednesday, October 29, 2008 4:49 PM
To: discuss at lists.osgeo.org
Subject: [OSGeo-Discuss] methods for programatically adding fields
toshapefiles
I am interested in approaches for adding a populated field to a
shapefile (for example, adding a new field named 'source_url' with the
value 'http://somewebsite.com').  I would like to do this for several
thousand files.
At first I thought that I might be able to accomplish it using ogr2org
with a sql clause, such as:
ogr2ogr -sql "select *, 'http://somewebsite.com' as source_url from
infile" outfile.shp infile.shp
but that didn't work since ogr2ogr supports a limited set of SQL,
described
at:
http://www.gdal.org/ogr/ogr_sql.html
Any ideas on how to accomplish this? (I would prefer suggestions that
can be scripted with python.)
- Tyler
View this message in context:
http://n2.nabble.com/methods-for-programatically-adding-fields-to-shapef
iles-tp1395535p1395535.html
Sent from the OSGeo Discuss mailing list archive at Nabble.com.
Discuss at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss mailing list
