[OSGeo-Discuss] methods for programatically adding fields to
shapefiles
Tim Sutton
tim at linfiniti.com
Fri Oct 31 15:49:51 EDT 2008
Hi
Are there any suggestions on how to do this from c++? Something we've
long wanted to add support for in QGIS.....
Frank Warmerdam was reticent about adding it to ogr since it would
have many crosscutting implications...
Regards
Tim
2008/10/31 Tyler Erickson <tyler.erickson at mtu.edu>:
> Thanks for all the suggestions. Although it is still a work in progress,
> it's looking like the ogr library approach suggested by David will work out
> for me...
> - Tyler
> def create_formatted_shapefile_using_ogr(infile, outfile):
> # setup a spatial reference
> srs_out = osr.SpatialReference()
> srs_out.SetFromUserInput('WGS84')
> ogrdriver = ogr.GetDriverByName('ESRI Shapefile')
> dsInput = ogrdriver.Open(infile)
> mLayer = dsInput.GetLayer()
> featureCount = mLayer.GetFeatureCount()
> # create the output shapefile
> if os.path.exists(outfile):
> ogrdriver.DeleteDataSource(outfile)
> dsOutput = ogrdriver.CreateDataSource(outfile)
> outLayer = dsOutput.CreateLayer(dsOutput.GetName(), \
> geom_type = ogr.wkbPolygon, \
> srs = srs_out)
> outLayer.CreateField(ogr.FieldDefn('start_date', ogr.OFTDate))
> outLayer.CreateField(ogr.FieldDefn('fire_code', ogr.OFTString))
> outLayer.CreateField(ogr.FieldDefn('fire_name', ogr.OFTString))
> outLayer.CreateField(ogr.FieldDefn('source', ogr.OFTString))
> print 'FeatureCount = ' + str(featureCount)
> for iFeature in range(0,mLayer.GetFeatureCount()):
> inFeature = mLayer.GetFeature(iFeature)
> geom = inFeature.GetGeometryRef()
> start_date = inFeature.GetFieldAsString('year') + "-" + \
> inFeature.GetFieldAsString('startmonth') + "-" + \
> inFeature.GetFieldAsString('startday')
> # reproject to WGS84
> geom.TransformTo(srs_out)
> # write the attributes to the output file
> outFeature = ogr.Feature(feature_def=outLayer.GetLayerDefn())
> outFeature.SetGeometry(geom)
> outFeature.SetFID(1)
> outFeature.SetField('fire_code', inFeature.GetField('fire_id'))
> outFeature.SetField('fire_name', inFeature.GetField('fire_name'))
> outFeature.SetField('source', infile)
> outLayer.CreateFeature(outFeature)
> outFeature.Destroy()
> inFeature.Destroy()
> dsInput.Destroy()
> dsOutput.Destroy()
> View this message in context: http://n2.nabble.com/methods-for-programatically-adding-fields-to-shapefiles-tp1395535p1437802.html
> Sent from the OSGeo Discuss mailing list archive at Nabble.com.
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
More information about the Discuss
