[OSGeo-Discuss] Questions about CS-Map, ArcSDE 9.3, buffer operations
surrounded Rob.Sosnowski at itd.idaho.gov
Fri Oct 3 07:48:02 PDT 2008
Excuse my ignorance - here goes,
I am building a GIS web application using FDO 3.3.1, C#.net, MS Virtual
Earth, and Silverlight.  As I am not sure of the relationship between OSGeo
and FDO, I will post these questions here:
1) I need to project coordinate systems (ex. WGS 1984 to state plane) and
cannot find a way to do this using FDO.  WHAT TOOLS ARE AVAILABLE UNDER THE
OSGeo UMBRELLA TO MAKE PROJECTIONS.  IF CS-MAP (recent donation from
AutoDesk) IS THE TOOL TO USE FOR PROJECTING COODINATE SYSTEMS, WHERE DO I
DOWNLOAD IT FROM?
2) FDO 3.3.1 currently supports ArcSDE 9.2.  DOES FDO 3.3.1 ALSO SUPPORT
ArcSDE 9.3?  IF NOT WHEN WILL THAT HAPPEN?
2) I need the ability to buffer features and cannot find a way to do this
using FDO.  WHAT OSGeo TOOLS ARE AVAILABLE FOR BUFFERING FEATURES WHOSE
OBJECTS ARE COMPATABLE WITH FDO?
Thanks for the help.....
View this message in context: http://n2.nabble.com/Questions-about-CS-Map%2C-ArcSDE-9.3%2C-buffer-operations-tp1142120p1142120.html
Sent from the OSGeo Discuss mailing list archive at Nabble.com.
More information about the Discuss mailing list
