[OSGeo-Discuss] Time window request on OGC protocol?
Raj Singh
raj at rajsingh.org
Fri Sep 26 09:43:06 EDT 2008
If all you need are time and bounding box parameters, WFS Simple might
be easier to implement than WFS:
http://www.ogcnetwork.net/wfssimple
Andrea does a good job of describing how to do a time query with WFS,
but it requires using Filter Encoding, which is a bit heavy.
I also have just created a sourceforge site for an open source Java
servlet implementation of WFS Simple:
http://sourceforge.net/projects/simplewfs/
Raj
On Sep 26, at 5:12 AM, Andrea Aime wrote:
> Domenico Febbo ha scritto:
>> Hi all,
>> maybe it is a very newbies' question:
>> I need to implement a Web Service based on GML that accept a XML
>> request
>> with two main things consist of:
>> 1) WGS84 coordinates for a geographical area
>> 2) the timeframe (start time and stop time) used to query to the
>> geodatabase
>> historical data.
>> It was very usefull (for me) to implement a web service over the WFS
>> protocol or other OGC standard protol,
>> but I didin't found a clear solution.
> WFS does not have a TIME parameter like WMS has, yet you can just
> publish the time attributes as part of your feature type, and
> create an OGC filter in your WFS request to filter upon them.
> For the details, I suggest you have a look at the WFS 1.0
> specification
> and at the Filter 1.0 specification (available at the OGC site),
> they are a dry read but should allow you to setup the request you're
> looking for.
> Cheers
> Andrea
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss
