[OSGeo-Discuss] Access to DWG 2008
Landon Blake lblake at ksninc.com
Thu Sep 4 09:04:14 PDT 2008
You're likely screwed. (We love you Autodesk.)
Can you get the data in DXF format?
As an alternative, you might look into buying a version of IntelliCAD.
It should be able to open an AutoCAD 2008 drawing file and only runs
about $200-$500 for the full version.
Landon
[mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Miguel Montesinos
Sent: Thursday, September 04, 2008 9:00 AM
To: discuss at lists.osgeo.org
Subject: [OSGeo-Discuss] Access to DWG 2008
Hello,
I need to access a DWG file in Autocad 2008 (dwg) format.
Does anyone know how to do it with an open-source application?
gvSIG opens DWG 2000. But further versions of DWG are encrypted and
their format are more than closed.
I'm really fed up with these closed requirements!
Any help will be appretiated. Even for crying purposes.
Regards,
Miguel Montesinos
Prodevelop
Warning:
Information provided via electronic media is not guaranteed against defects including translation and transmission errors. If the reader is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this information in error, please notify the sender immediately.
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20080904/306f5a9f/attachment-0002.html>
More information about the Discuss mailing list
