[OSGeo-Discuss] Access to DWG 2008
Miguel Montesinos mmontesinos at prodevelop.es
Fri Sep 5 01:31:40 PDT 2008
Thanks everybody for your help.
I'll check your hints.
Regards,
Miguel Montesinos
> -----Mensaje original-----
> De: discuss-bounces at lists.osgeo.org [mailto:discuss-
> bounces at lists.osgeo.org] En nombre de Brent Fraser
> Enviado el: jueves, 04 de septiembre de 2008 18:40
> Para: OSGeo Discussions
> Asunto: Re: [OSGeo-Discuss] Access to DWG 2008
> You could use AnyDWG (shareware and Windows only) to convert from DWG
> 2008 to DWG (or DXF) 2000.
> http://anydwg.com/dwg-dxf/
> Brent Fraser
> Miguel Montesinos wrote:
> > Hello,
> > I need to access a DWG file in Autocad 2008 (dwg) format.
> > Does anyone know how to do it with an open-source application?
> > gvSIG opens DWG 2000. But further versions of DWG are encrypted and
> > their format are more than closed.
> > I'm really fed up with these closed requirements!
> > Any help will be appretiated. Even for crying purposes.
> > Regards,
> > Miguel Montesinos
> > Prodevelop
> > Discuss mailing list
> > Discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss mailing list
