[OSGeo-Discuss] Open Source Library For ECW Conversion
Tamas Szekeres szekerest at gmail.com
Wed May 13 13:21:07 EDT 2009
GDAL has working SWIG bindings for Java and you could do the same as
gdal_translate is doing by using the SWIG API.
Some examples about how to use the java bindings can be found in the GDAL
source tree:
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/java/apps
Best regards,
Tamas
2009/5/13 Landon Blake <lblake at ksninc.com>
> Daniel,
> I think this would do the trick. I know just enough shell scripting to
> be dangerous, but I think that I could pull this off.
> I appreciate the suggestion.
> Landon
> Office Phone Number: (209) 946-0268
> Cell Phone Number: (209) 992-0658
> -----Original Message-----
> From: discuss-bounces at lists.osgeo.org
> [mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
> Sent: Wednesday, May 13, 2009 8:11 AM
> To: OSGeo Discussions
> Subject: Re: [OSGeo-Discuss] Open Source Library For ECW Conversion
> Landon Blake wrote:
> > I'm looking for an open source library that will allow me to convert
> ECW
> > images into a more common format like JPG or TIFF. I'd love it if
> there
> > were something in Java, but I'm not running across anything via search
> > engine query so far.
> Sounds like a job for gdal_translate:
>   http://gdal.org/gdal_translate.html
> Don't let the complicated list of options scare you... for a simple
> conversion you'd use something like:
>   gdal_translate -of GTiff src.ecw out.tif
> Not in Java, but you don't need to do any coding anyway, except perhaps
> write a script to run multiple conversions in batch.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
> Warning:
> Information provided via electronic media is not guaranteed against defects
> including translation and transmission errors. If the reader is not the
> intended recipient, you are hereby notified that any dissemination,
> distribution or copying of this communication is strictly prohibited. If you
> have received this information in error, please notify the sender
> immediately.
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20090513/f6bbcb52/attachment-0001.html
More information about the Discuss mailing list
