[OSGeo-Discuss] Comparision between MapServer/OpenLayers and
ESRI ArcIMS
John Callahan
john.callahan at UDel.Edu
Thu May 28 10:01:58 EDT 2009
To follow up re: status of ArcIMS
I just checked the ESRI site, clicked on Products, Server GIS and ArcIMS
is nowhere to be found. As well, if you select Training and search for
courses, you will find exactly "zero" instructor-led courses for
ArcIMS. (ArcIMS is also listed under "Other Products" in the Training
section.) So, as far as I'm concerned, ArcIMS is dead and everything
goes through ArcGIS Server with ESRI.
- John
Bill Thoen wrote:
> Thanks for the help folks, especially to John Callahan. That was the
> best description of the problem with the ESRI solution that I've seen
> to date. What they offer may be good or not --I don't have the
> experience to argue that point-- but they are even more expensive that
> I had imagined. I'm very impressed with ESRI's marketing -- if they
> can sell this, they could sell snow to Santa Claus!
> Regards,
> - Bill Thoen
More information about the Discuss
