[OSGeo-Discuss] Need recommendation: Base map + WKTs to JPG
Bob Basques
bob.b at gritechnologies.com
Thu Oct 29 22:08:05 EDT 2009
Clark,
There is a fairly well thought out PDF maker that is PHP based inside
of GeoMoose. Might be a place to start.
bobb
Clark Woodward wrote:
> I am looking for recommendations the Open Source community for the
> following application. Currently I have an OpenLayers map that is
> dynamically generated with a Google base map and 3 WKT polygons with
> styles applied. All layers are projected as Spherical Mercator. I
> programmatically execute the map and scrape the map to a JPG image.
> This map is called from another application and there is no user
> interaction; everything is automated.
> Since OpenLayers is drawing within the browser and is not intended to
> be captured and saved, my current approach isn't working very well.
> If anyone has an alternate approach, I would very much appreciate
> hearing your ideas.
> My requirements are
> 1. Display Google base map
> 2. Support WKT
> 3. Support custom symbology
> 4. Export to JPG (or other image format) programmatically
> Thanks
> Clark
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20091029/f8ef3696/attachment.html
More information about the Discuss
