[OSGeo-Discuss] Remote routing solutions
Chris Holmes cholmes at opengeo.org
Tue Oct 6 18:53:52 PDT 2009
We've actually also just kicked off an open source routing engine
project, attempting to collaborate with all the open source trip
planners we knew about at the time.
See http://opentripplanner.org/
We're working with Brandon of GraphServer, as well as the developers of
Five Points (see http://new.atltransit.com/), One Bus Away (which has a
trip planner) and ByCycle.org
Focused on multi-modal, to replace the routing engine at
http://ride.trimet.org/ (currently the only proprietary piece of their
whole map).  Though we might also have a bike routing use case soon.
Steven - it'd be great to collaborate in some way: if it's too late to
collaborate on code we could at least build a common API.  In time we're
hoping to establish a nice library of transit specific GeoExt type
components.  So people could easily use OpenLayers and Ext.js to compose
a transit map like Portland's.  It'd be great if those components could
talk to the same routing API, and indeed could be the start of an
improved open standard.
best regards,
Chris
Stephen Woodbridge wrote:
> Mateusz Loskot wrote:
>> Folks,
>> May I kindly ask for a bit of brainstorming about
>> available and programmatically callable,
>> optionally usable,
>> optionally effective,
>> optionally robust
>> solutions of remote routing services?
>> The use case is very simple:
>> 1) client is a non-Web thin client
>> 2) client has access to the Internet
>> 3) client knows two locations "start" and "destination"
>> 4) client wants to know how to travel from start to destination
>> What are available options to achieve that? Where if availability means:
>> * accessible for public
>> * free of charge
>> * does not require to sign anything,
>> Custom solutions built on OGC-enabled stack (e.g. PyWPS, etc.) is also
>> an option to discuss.
>> Any input greatly appreciated.
>> Best regards,
> Mateusz,
> Is the client looking for a solution that runs somewhere on the net that
> they can make requests to, or are they looking to setup a server with
> data and a routing engine?
> So I'll plug my infant and immature routing engine project:
> http://sourceforge.net/projects/opengraphrouter/
> Also pgRouting is an option.
> The big issues in most cases will be data. Some people are doing routing
> with OpenStreetMap and pgRouting. If they want accurate (ie: navigable
> routes then they will probably need something based on Navteq or
> TeleAtlas) or if they are look at a small county or state wide area then
> they might be able to get data from the local governments like
> http://www.mass.gov/mgis/mapping.htm
> Because good data is expensive and licensed, in most cases by
> transactions, it is not likely that you will find services equivalent to
> Google that are free.
> -Steve W
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
Chris Holmes
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Discuss mailing list
