[OSGeo-Discuss] Re: Automatic-Metadata Catalogueing
Martin Seiler
martin.seiler at gmx.de
Tue Aug 24 07:39:50 EDT 2010
> I found two solutions:
> * SpatialDataCataloguingScript at
> http://code.google.com/p/spatialguru/wiki/SpatialDataCataloguingScript
> => this works well after some fixing.
> But how do I best use the generated XML file?
> Apparently, gvSIG has some tool as well:
> Semi-automatic Metadata Extraction from Imagery and Cartographic data
> http://www.geoinfo.uji.es/pubs/igarss07-metadata-cameraready.pdf
You also might want to take a look at CatMDEdit [1].
Not too long ago I did a survey on Metadata-Editors regarding their
ability to extract metadata in a semi-automatic manner. It seems to be
a widely neglected field, with a lot of potential...
CatMDEdit was the most useful editor that I've tested, but in the end it
didn't fulfill the requirements. I also ended up writing python scripts
that make use of gdal/ogr, creating ISO- and INSPIRE-complaint metadata
sets.
Ciao,
Martin
[1] http://forge.osor.eu/projects/catmdedit/
More information about the Discuss
