[OSGeo-Discuss] mxd to other format (i.e. shapefile)
Noli Sicad nsicad at gmail.com
Mon Aug 2 19:35:06 PDT 2010
Hi Maning,
You can try ArcMap2SLD. It convert *.mxd to SLD.
Download it here.
http://wald.intevation.org/frs/?group_id=32&release_id=213
http://www.cadmaps.com/gisblog/?p=75
Regards, Noli
On 8/3/10, maning sambale <emmanuel.sambale at gmail.com> wrote:
> No luck so far looking for a converter.
> Basically, I want to export geometry and attributes without the
> styling from an Arc's mxd format to shapefile.
> Any workaround here (other then looking for an ArcGIS installed machine)?
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss mailing list
