[OSGeo-Discuss] Online shapefile Viewer
Dan Putler dan.putler at sauder.ubc.ca
Sun Apr 3 14:26:15 EDT 2011
Hi Rashad,
I couldn't connect. I couldn't actually connect to www.iiit.ac.in
either, so there might be a problem at the university level at the moment.
Is the usage model one in which you connect and then upload a shapefile
for display?
Dan
On 04/03/2011 11:20 AM, Mohammed Rashad wrote:
> yes the our sever is facing some problems and will recover it as soon
> as possible
> Its not opensource currently but we are planning to release the
> application as Open source GPL probably in May
> we are also working on a collaborative mapping plaform VRGeo
> Did you tried with any shapefiles
> On Sun, Apr 3, 2011 at 11:47 PM, Dan Putler <dan.putler at sauder.ubc.ca
> <mailto:dan.putler at sauder.ubc.ca>> wrote:
>     Hi Rashad,
>     Is the viewer open source software?
>     I've gone to the site, and response is fairly slow. Although,
>     given the likely interest in this, you may be getting a *lot* of
>     hits at the moment.
>     Dan
>     On 04/03/2011 11:08 AM, Mohammed Rashad wrote:
>         Hi,
>         I am posting here because gis users may find this application
>         useful.
>         here is an online shapefile viewer which reads shapefile using
>         OGR and rendered on webpage.
>         http://lsi.iiit.ac.in/lsi/shpviewer/
>         Here the shapefile is directly rendered without mapserver,
>         geoserver like packages.The only library we used is GDAL
>         Please test it.
>         Looking forward your comments, BUGS && suggestions
>         Thanks && Regards
>         Rashad
>     _______________________________________________
>     Discuss mailing list
>     Discuss at lists.osgeo.org <mailto:Discuss at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/discuss
> Thanks && Regards
> Rashad
More information about the Discuss mailing list
