[OSGeo-Discuss] Re: [OSGeo-Standards] Re: [Board] Open Source and Open Standards White Paper
Cameron Shorter cameron.shorter at gmail.com
Thu Apr 14 20:29:28 EDT 2011
Arnulf,
Sorry for the delayed review, and rather messy use of email in applying
my review comments:
I assume that the target audience for this white paper is:
* People who don't understand the difference between "Standards" and
"Open Standards"
* People who don't understand the difference between "Proprietary
Software", "Freeware", "Open Source"
* People who may understand the terms "Open Source" and "Open Standards"
but don't appreciate the strengths (and weaknesses) of these models over
the alternatives.
As a general comment, I feel that much of this paper uses terms which
are only understood by seasoned developers who already understand what
Open Source and Open Standards are, and as such I feel that the paper is
"preaching to the converted". For instance, there are concepts which are
introduced, like the Open Sourced development practices, which are left
hanging without an explanation. A reader not familiar with Open Source
will be left wondering "so why should I care about these practices". I
suggest that if these concepts are introduced they need to be expanded
upon and describe why they are important.
Further are some more specific comments:
* 1st Introduction paragraph:
This should be concise, and describe what the white paper is about. It
is not the place to reference source material. It needs to include a
sentence or two describing what the OGC and OSGeo organisations are.
Of note: I have been at many geospatial trade shows and almost always
talk to a few people who don't know what the OGC is, or what OSGeo is.
* Under "Open Standards":
** I feel the first few paragraphs should define what an Open Standard
is in the first paragraph before expanding.
** I feel that the section "OGC's position regarding Open Source
Software" does a better job of describing importance of standards than
this section.
** The list of criteria for a standard is good. I'd like to see each one
of these points expanded on, and provide a description of why that
criteria is important. In particular, I suggest that a counter example
will usually benefit the description. Eg: Explain the limitations with a
company publishing an API then calling it a standard?
** After reading this section, someone should understand why it is
important to use Open Standards. I'd expect to see discussion of
Inter-Operability, Reduced cost of data processing, Reduced long term
maintenance cost, reduced risk due to obsolescence of products, reduced
risk of vendor lock in.
** I've recently been refuting claims (at a National Government Policy
level) that the ESRI REST API is an Open Standard because REST is an
open standard. While I don't suggest picking on this as an example, it
would be valuable if the reader can understand the difference between
extensions to a base standard, and an overlying API.
* In "Proprietary Software", I suggest that you don't pull out "java" as
a specific example. It is too "down in the the weeds" for this type of
high level document, and will likely confuse rather than help readers.
If the java issues are to be explained, then much more detail should be
included about the specific java case, and I don't think that is
appropriate here.
* In "Open Data", I think this section requires a stronger statement
about what Open Data is. We should state what we believe "Open Data" to
mean. The Creative Commons licence should be mentioned, and note how it
is applicable to documents with just a few authors. We should note how
Open Street Map is moving away from Creative Commons due to the
practical limitations associated with crediting thousands or millions of
authors, as is often the case with geospatial data sets.
* In "Similarities and differences":
** terms such as “benevolent dictator” and “rough consensus” should be
explained if they are to be used.
** IPR accronym should be expanded.
** I feel the discussion of the OGC "Reference Architecture" is
wishy-washy. We have some very clear guidelines about what is Open
Source and what is not (as explained above). Either say that the
Reference Architecture is Open Source, or don't mention it.
* OSGeo's position regarding Open Standards:
** Re: "... ideally simply [standards] because they are good." "good"
needs to be expanded if this statement is to be made. Why are simple
standards good? I think this statement should be dropped, or else it
needs a paragraph or two discussing the pros of a comprehensive standard
vs the pros of a simple standard. I think the answer to this question is
more than "simple is the best version of a standard in all cases". I
think it would be closer to "it is preferable that all standards, even
complex standards, include a simple mandatory core version of the
standard which is easy to implement which leads to widespread adoption
of the standard."
* Memorandum of Understanding:
** I assume the 6 OGC memberships are for "OSGeo members"? If so, this
should be mentioned.
* Please be consistent with capitalisation: Either ("open source" and
"open standards") or ("Open Source" and "Open Standards").
On 15/04/2011 4:55 AM, Seven (aka Arnulf) wrote:
> Folks,
> please be so kind and give this paper a moment of your attention:
> http://wiki.osgeo.org/wiki/Talk:Open_Source_and_Open_Standards
> There is still a lot of confusion in people as to what an Open
> Standard is and what Open Source is. Even within the educated
> community of OSGeo there are very different positions wrt to standards
> and what an Open Standards should be. It ranges from "standards suck
> and prevent innovation" to "standards are the only way out of the
> misery of the data silos".
> The same is true to what the educated part of the OGC community thinks
> about Open Source ranging from... well you know. No need to repeat here.
> Therefore OGC and OSGeo are interested to find a common position on
> Open standards and Open Source and if we don't disagree too badly this
> will become a joint white paper. Please give it a pass and comment if
> you think something is seriously wrong.
> On 04/13/2011 09:42 PM, Markus Neteler wrote:
>> On Wed, Apr 13, 2011 at 9:02 PM, Seven (aka Arnulf)<seven at arnulf.us>
>> wrote:
>>> Folks,
>>> as discussed on IRC we have further developed the article on Open
>>> Source and
>>> Open Standards:
>>> It would be great if you could give it a pass
>> I have done a few edits (see history).
>> Markus
> Thanks Markus,
> anyone else from the board with comments? The page had 100 views in
> the past two days and if no one else follows up with comments I
> consider this to be generally accepted.
> Best regards,
> Arnulf.
> PS:
> I am sure that as soon as we publish it the usual die hards will start
> to scream at the top of their lungs :-) but we can probably not do
> much more than we did, can we?
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Discuss mailing list
