[OSGeo-Discuss] Batch geocoding
JP Glutting
jpglutting at gmail.com
Fri Feb 4 09:01:02 EST 2011
Thanks Pieter.
Geomajas looks very nice! I don't mind rolling my own, but this is just a
preliminary part of a big project (my Masters thesis), and I only need to
geocode the data once. You don't know of any code or solutions I could take
a look at that implement a solution like this?
Thanks,
JP
On Fri, Feb 4, 2011 at 2:48 PM, Pieter De Graef <pieter.degraef at geosparc.com
> wrote:
> When we created the GeoCoder plugin for Geomajas we faced that same
> problem. The google geocoder has a few drawbacks that makes it unsuitable.
> In the end we used the Yahoo service together with the Geonames service,
> with pretty good results.
> Hope that helps.
> On 02/04/2011 02:34 PM, JP Glutting wrote:
> Hello,
> I have a large set of addresses (around 150k) that I need to geocode for
> a study (my Masters thesis on heat-related mortality). I am looking into
> different solutions, but I can't find anything that seems like it would work
> properly.
> I could script a solution using Google's map API, but there is a limit of
> 2,500 addreses per day (I can get around them with a little patience).
> Right now the best solution I am looking at geopy for geocoding addresses
> (http://code.google.com/p/geopy/). It seems like a good system, I think I
> can use it to pull addresses out of my database and write back coordinates.
> There is one thing that I am not sure, about, though, is whether I am
> actually allowed to use the Google API without my use being liked to a
> specific web page. The terms of service and form for getting a Google API
> key require a URL linked to a Google account. In fact, it looks like the API
> can only be used through a web site:
> "5.2 *Account Key*. After supplying Google with your account information
> and the URL of your Maps API Implementation, and accepting the Terms, you
> will be issued an alphanumeric key assigned to you by Google that is
> uniquely associated with your Google Account and the URL of your Maps API
> Implementation. Your Maps API Implementation must import the Google Maps
> APIs using this key as described in the Maps APIs Documentation<http://code.google.com/apis/maps/documentation/>,
> and Google will block requests with an invalid key or invalid URL. You may
> only obtain and use a key in accordance with these Terms and the Maps APIs
> Documentation <http://code.google.com/apis/maps/documentation/>."
> So it looks like I can't even get it to work without a URL.
> I can always write a script that loops through results extracted from the
> database, creates URLs and parses the XML results one at a time, but that
> seems like a fairly inelegant solution.
> Does anyone have any good ideas about how to geocode a few thousand
> addresses?
> Many thanks,
> JP
> Discuss mailing listDiscuss at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/discuss
> Pieter De Graef
> Community Manager
> GeoSparc nv.http://www.geosparc.com/
> Chairman of the Geomajas projecthttp://www.geomajas.org/
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20110204/714936ba/attachment-0001.html
More information about the Discuss
