[OSGeo-Discuss] Batch geocoding
Jean-Philippe Lagrange
Jean-Philippe.Lagrange at ign.fr
Fri Feb 4 08:48:38 EST 2011
Hi JP
Please keep in mind that when using the Google Maps services you accept the following terms:
By submitting, posting or displaying Your Content in the Service, you give Google a perpetual, irrevocable, worldwide, royalty-free, and non-exclusive license to reproduce, adapt, modify, translate, publicly perform, publicly display and distribute Your Content through the Service and as search results through Google Services.
http://code.google.com/intl/fr/apis/maps/terms.html
(sec. 11.1)
JP
De : discuss-bounces at lists.osgeo.org [mailto:discuss-bounces at lists.osgeo.org] De la part de JP Glutting
Envoyé : vendredi 4 février 2011 14:34
À : discuss at lists.osgeo.org
Objet : [OSGeo-Discuss] Batch geocoding
Hello,
I have a large set of addresses (around 150k) that I need to geocode for a study (my Masters thesis on heat-related mortality). I am looking into different solutions, but I can't find anything that seems like it would work properly.
I could script a solution using Google's map API, but there is a limit of 2,500 addreses per day (I can get around them with a little patience).
Right now the best solution I am looking at geopy for geocoding addresses (http://code.google.com/p/geopy/). It seems like a good system, I think I can use it to pull addresses out of my database and write back coordinates. There is one thing that I am not sure, about, though, is whether I am actually allowed to use the Google API without my use being liked to a specific web page. The terms of service and form for getting a Google API key require a URL linked to a Google account. In fact, it looks like the API can only be used through a web site:
"5.2 Account Key. After supplying Google with your account information and the URL of your Maps API Implementation, and accepting the Terms, you will be issued an alphanumeric key assigned to you by Google that is uniquely associated with your Google Account and the URL of your Maps API Implementation. Your Maps API Implementation must import the Google Maps APIs using this key as described in the Maps APIs Documentation<http://code.google.com/apis/maps/documentation/>, and Google will block requests with an invalid key or invalid URL. You may only obtain and use a key in accordance with these Terms and the Maps APIs Documentation<http://code.google.com/apis/maps/documentation/>."
So it looks like I can't even get it to work without a URL.
I can always write a script that loops through results extracted from the database, creates URLs and parses the XML results one at a time, but that seems like a fairly inelegant solution.
Does anyone have any good ideas about how to geocode a few thousand addresses?
Many thanks,
JP
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20110204/a656a9a7/attachment.html
More information about the Discuss
