[OSGeo-Discuss] Batch geocoding
JP Glutting
jpglutting at gmail.com
Fri Feb 4 16:27:49 EST 2011
Hi Wladimir,
That is sort of what I thought. Too bad. I was just in Barcelona yesterday,
at the CSIC, to get data. Where do you work?
I am on the geoinquiets list too, but I am afraid I am on so many lists and
in so many projects that I don't keep close track of them all. I should hop
over and introduce myself, though.
Fins aviat,
JP
Public Health - GIS - Bioinformatics
http://www.bmeisis.com
<http://www.bmeisis.com/>http://www.jpglutting.com
On Fri, Feb 4, 2011 at 7:18 PM, Wladimir Szczerban <bolosig at gmail.com>wrote:
> Hi JP,
> I live in Barcelona and unfortunately there is no open geocoding service
> in Barcelona. In the group of geoinquietos (http://www.geoinquiets.cat/ or
> http://wiki.osgeo.org/wiki/Geoinquiets_Barcelona) we are trying to get the
> ICC (http://www.icc.cat/) the official agency open the geocoding service they
> have.
> Cheers,
> BOLO
> 2011/2/4 Stark Hans-Jörg <hansjoerg.stark at fhnw.ch>
> Any initiative for OA is appreciated highly ;o)
>> Best,
>> hj
>> *Von:* discuss-bounces at lists.osgeo.org [mailto:
>> discuss-bounces at lists.osgeo.org] *Im Auftrag von *JP Glutting
>> *Gesendet:* Freitag, 4. Februar 2011 16:17
>> *An:* OSGeo Discussions
>> *Betreff:* Re: [OSGeo-Discuss] Batch geocoding
>> There might be a data sharing initiative, there are several different
>> actors (city, regional government, etc.). I don't know all of what there is
>> out there, and the data was originally collected for another project.
>> I think I will be Ok with Yahoo. If it works out, it shouldn't be
>> difficult to export the dataset for openaddresses. It isn't my data, though,
>> so I will have to ask permission first. It seems like a good idea, though.
>> Cheers,
>> JP
>> On Fri, Feb 4, 2011 at 3:49 PM, Stark Hans-Jörg <hansjoerg.stark at fhnw.ch>
>> *Gesendet:* Freitag, 4. Februar 2011 15:34
>> Hi Hans-Jörg,
>> I am not aware that Barcelona (the city?) has a very open geodata
>> strategy, but that certainly would be nice. If you know of anyone in the
>> area who might know more, I am more than willing to contact them.
>> *[shj] my mistake. I thought I had read something on this some time ago.
>> Maybe also because Spain has strong support in the FOSS domain.*
>> I have the addresses, do you mean the coordinates? The address format is
>> not ideal, but I am pretty happy with them, as they seem to geocode well in
>> the tests I have done.
>> *[shj] yes, addresses along with co-ordinates.*
>> The Yahoo API allows geocoding of 50k addresses a day, which is plenty for
>> what I need. I am going to try to use that.
>> *[shj] that’ll certainly do.*
>> Cheers,
>> JP
>> On Fri, Feb 4, 2011 at 3:26 PM, Stark Hans-Jörg <hansjoerg.stark at fhnw.ch>
>> wrote:
>> Hi JP
>> Barcelona is unfortunately not well covered yet in OA. But I thought that
>> Spain has a very “open” strategy in terms of providing geodata. If you
>> manage to get Barcelona addresses (perhaps from council or any other
>> “official body”) the OA team will insert these into OA and then you can use
>> the REST service.
>> Good luck!
>> -hj
>> *Gesendet:* Freitag, 4. Februar 2011 15:24
>> Thanks for all the responses! I will track them all down and see how they
>> work.
>> Stark, I have 146,472 addresses in the city of Barcelona. Many of them are
>> duplicates, but at the very least I have 31,514 that need to be coded,
>> although that would leave out many that I want to use. I am in the process
>> of developing filters to clean out apartment numbers, etc., to be able to
>> pull a single coordinate for a whole set of addresses, and there are at
>> least 6,000 that are invalid (from the original 146k, so 140k). It is a lot.
>> I will take a look at openaddresses and do some testing.
>> Thanks!
>> JP
>> On Fri, Feb 4, 2011 at 3:10 PM, Stark Hans-Jörg <hansjoerg.stark at fhnw.ch>
>> wrote:
>> The OpenAddresses project (www.openaddresses.org) is supposed to solve
>> exactly your problem.
>> You can use the provided geocoding services (
>> http://code.google.com/p/openaddresses/wiki/RESTService)
>> OpenAddresses has some regions where data was donated – there you will get
>> high-quality results. Unfortunately this is not yet globally available…
>> Hth
>> -hj
>> *Gesendet:* Freitag, 4. Februar 2011 14:34
>> *An:* discuss at lists.osgeo.org
>> *Betreff:* [OSGeo-Discuss] Batch geocoding
>> Hello,
>> I have a large set of addresses (around 150k) that I need to geocode for a
>> study (my Masters thesis on heat-related mortality). I am looking into
>> different solutions, but I can't find anything that seems like it would work
>> properly.
>> I could script a solution using Google's map API, but there is a limit of
>> 2,500 addreses per day (I can get around them with a little patience).
>> Right now the best solution I am looking at geopy for geocoding addresses
>> (http://code.google.com/p/geopy/). It seems like a good system, I think I
>> can use it to pull addresses out of my database and write back coordinates.
>> There is one thing that I am not sure, about, though, is whether I am
>> actually allowed to use the Google API without my use being liked to a
>> specific web page. The terms of service and form for getting a Google API
>> key require a URL linked to a Google account. In fact, it looks like the API
>> can only be used through a web site:
>> "5.2 *Account Key*. After supplying Google with your account information
>> and the URL of your Maps API Implementation, and accepting the Terms, you
>> will be issued an alphanumeric key assigned to you by Google that is
>> uniquely associated with your Google Account and the URL of your Maps API
>> Implementation. Your Maps API Implementation must import the Google Maps
>> APIs using this key as described in the Maps APIs Documentation<http://code.google.com/apis/maps/documentation/>,
>> and Google will block requests with an invalid key or invalid URL. You may
>> only obtain and use a key in accordance with these Terms and the Maps
>> APIs Documentation <http://code.google.com/apis/maps/documentation/>."
>> So it looks like I can't even get it to work without a URL.
>> I can always write a script that loops through results extracted from the
>> database, creates URLs and parses the XML results one at a time, but that
>> seems like a fairly inelegant solution.
>> Does anyone have any good ideas about how to geocode a few thousand
>> addresses?
>> Many thanks,
>> JP
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/discuss
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20110204/83ef537d/attachment-0001.html
More information about the Discuss
