[OSGeo-Discuss] Batch geocoding
Dan Putler
dan.putler at sauder.ubc.ca
Fri Feb 4 18:17:59 EST 2011
Glad to be of help, I'm just curious about what the licensing / terms of
use on the KML files that come out of fusion tables. Plus I want to know
if it will reverse geocode. It is very slick, but I can imagine
violating the terms of use almost instantly.
In terms of your next problem (which seems like one for the PostGIS user
list), did you create a unique address ID? if you did, can't you put it
in the data you created the fusion table from and then just do the
appropriate table join in Postgres/PostGIS?
Dan
On 02/04/2011 03:08 PM, JP Glutting wrote:
> That is a nice trick, I will remember that. I really just need the
> coordinates, since each coordinate needs to go back into a database in
> a register of a location-time that needs more data added later. These
> are the "generic" addresses, with the apartment numbers stripped, so
> each address will provide coordinates for multiples DB entries on
> different dates, and I won't really be using them on the same layer.
> But I am sure I can figure out a way to get the data back out with
> PostGIS (the original data is in Postgres anyway).
> Cheers,
> JP
> On Fri, Feb 4, 2011 at 11:59 PM, Dan Putler <dan.putler at sauder.ubc.ca
> <mailto:dan.putler at sauder.ubc.ca>> wrote:
> JP,
> If you export the KML, and then feed it into QGIS you can then
> save the resulting layer as a shapefile, which is probably what
> you are really hoping to have since you can then easily feed it to
> R, PostGIS, or a number of other tools to pull the coordinates.
> Dan
> On 02/04/2011 02:20 PM, JP Glutting wrote:
> Hi Bernie,
> You can't actually get the lat-lng back out of a Fusion table.
> It will geocode all the addresses, but you can't get the
> numbers back, you can just make a map or layer or something.
> http://groups.google.com/group/fusion-tables-users-group/browse_thread/thread/91c43c73107164eb
> Unless I export it to KML and pull it back out of there?
> That seems like a lot of work. But it sure geocodes like
> gangbusters.
> Cheers,
> JP
> Public Health - GIS - Bioinformatics
> http://www.bmeisis.com <http://www.bmeisis.com/>
> http://www.jpglutting.com
> On Fri, Feb 4, 2011 at 7:42 PM, Connors, Bernie (SNB)
> <Bernie.Connors at snb.ca <mailto:Bernie.Connors at snb.ca>
> <mailto:Bernie.Connors at snb.ca <mailto:Bernie.Connors at snb.ca>>>
> wrote:
> Try Google Fusion Tables. All you have to do is put all of the
> address components in one field and it should be recognized and
> geocoded.
> *Bernie Connors, P.Eng*
> Service New Brunswick
> (506) 444-2077
> 45°56'25.21"N, 66°38'53.65"W
> www.snb.ca/geonb/ <http://www.snb.ca/geonb/>
> *From:*discuss-bounces at lists.osgeo.org
> <mailto:discuss-bounces at lists.osgeo.org>
> <mailto:discuss-bounces at lists.osgeo.org>>
> [mailto:discuss-bounces at lists.osgeo.org
> <mailto:discuss-bounces at lists.osgeo.org>>] *On Behalf Of *JP
> Glutting
> *Sent:* Friday, 2011-02-04 09:34
> *To:* discuss at lists.osgeo.org
> <mailto:discuss at lists.osgeo.org>
> <mailto:discuss at lists.osgeo.org <mailto:discuss at lists.osgeo.org>>
> *Subject:* [OSGeo-Discuss] Batch geocoding
> Hello,
> I have a large set of addresses (around 150k) that I need to
> geocode for a study (my Masters thesis on heat-related
> mortality).
> I am looking into different solutions, but I can't find
> anything
> that seems like it would work properly.
> I could script a solution using Google's map API, but there
> is a
> limit of 2,500 addreses per day (I can get around them with a
> little patience).
> Right now the best solution I am looking at geopy for geocoding
> addresses (http://code.google.com/p/geopy/). It seems like
> a good
> system, I think I can use it to pull addresses out of my
> database
> and write back coordinates. There is one thing that I am
> not sure,
> about, though, is whether I am actually allowed to use the
> Google
> API without my use being liked to a specific web page. The
> terms
> of service and form for getting a Google API key require a URL
> linked to a Google account. In fact, it looks like the API can
> only be used through a web site:
> "5.2 _Account Key_. After supplying Google with your
> account
> information and the URL of your Maps API
> Implementation, and
> accepting the Terms, you will be issued an alphanumeric key
> assigned to you by Google that is uniquely associated with
> your Google Account and the URL of your Maps API
> Implementation. Your Maps API Implementation must
> import the
> Google Maps APIs using this key as described in the
> Maps APIs
> Documentation
> <http://code.google.com/apis/maps/documentation/>, and Google
> will block requests with an invalid key or invalid URL. You
> may only obtain and use a key in accordance with these
> Terms
> and the Maps APIs Documentation
> <http://code.google.com/apis/maps/documentation/>."
> So it looks like I can't even get it to work without a URL.
> I can always write a script that loops through results
> extracted
> from the database, creates URLs and parses the XML results
> one at
> a time, but that seems like a fairly inelegant solution.
> Does anyone have any good ideas about how to geocode a few
> thousand addresses?
> Many thanks,
> JP
> Discuss mailing list
> Discuss at lists.osgeo.org <mailto:Discuss at lists.osgeo.org>
> <mailto:Discuss at lists.osgeo.org <mailto:Discuss at lists.osgeo.org>>
> http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss
