[OSGeo-Discuss] Re: Advice on implementing VRP in FOSS4G
cremat0rio
davidsantospinheiro at gmail.com
Thu Feb 24 07:17:30 EST 2011
Hi Daniel!
Thanks a lot for your response and suggestion.
I'll try to look at the openVRP project and maybe we can go that way
(through pgrouting).
Best regards,
David
On Mon, Feb 14, 2011 at 3:27 PM, Daniel Kastl-4 [via OSGeo.org] <
ml-node+6023938-832396173-182590 at n2.nabble.com> wrote:
> Hi David,
> We have implemented something like this last year for pgRouting (extension
> of PostGIS/PostgreSQL). It's very similar to what you describe.
> Our goal was to have some genetic algorithm to solve the dial-a-ride
> problem for bus-on-demand as described here
> http://openvrp.com/blog/darp-algorithm-in-pgrouting/ or here
> http://georepublic.de/en/projects/openvrp/
> <http://openvrp.com/blog/darp-algorithm-in-pgrouting/>It was a funded
> research project and we're currently implementing a real bus-on-demand
> system using taxis and micro-buses.
> There are plenty of similar problems related to VRP and a lot
> of possibilities to add new functionality as you describe. If you're
> interested you can join the pgRouting community (http://www.pgrouitng.org)
> and we can discuss details there.
> Best regards,
> Daniel
> 2011/2/15 cremat0rio <[hidden email]<http://user/SendEmail.jtp?type=node&node=6023938&i=0>
>> Hi everyone!
>> I’m new on this list, so all the best for all of you and for OSGeo!
>> I’m writing to get some advice. For my master degree project, I’ll try to
>> create some code to solve Vehicle Routing Problem (VRP) through
>> Evolutionary
>> Computation techniques (Genetic Algorithms and stuff like that). It would
>> be
>> very good to put this code to work on some GIS desktop Software and make
>> it
>> simple to use, suitable for any layperson.
>> VRP is a problem where you have some vehicles that need to serve some
>> places, and you want to distribute them through that area reducing their
>> overall cost (is terms of fuel consumption, time spent, eco impact, etc.).
>> For example, distributing waste collection trucks to different areas of a
>> city, or mailmen’s through some city, or some companies’ trucks that need
>> to
>> serve mail packages to a country, etc… All this problems have in common
>> that
>> we want the vehicles (or humans) to be routed on the network to serve some
>> locations.
>> In terms of implementation we need a LINESTRING layer representing the
>> road
>> network (of some city, for example) and a POINT (or POLYGON) layer
>> representing the places that need to be visited (served). Then given some
>> vehicle’s positions and capacities, and some charging/discharging places
>> the
>> code would calculate good routes that minimize the mentioned costs.
>> As I’ve said, it would be good for this package/software to be suitable
>> for
>> use for any person, so a Desktop GIS implementation would be good.
>> The problem is that there seems to be two main computing language
>> paradigms
>> in the FOOS4G Desktop GIS software’s, Java vs C++. Which one to choose?
>> Which DesktopGis software? Or should I implement something (some function)
>> in Postgres/Postgis? Or on the command line (on top of OGR)?
>> In the beginning I thought that a plugin for QuantumGis would be the best
>> option because the plugins are relatively independent of the core
>> developer’s work/supervision, and anyone can choose to install it or not.
>> But this way people that use Java based DesktopGIS (like gvSig) couldn’t
>> benefit from this work…
>> So, I’m asking for your kind advice.
>> Any help/advice will be much appreciated!
>> All the best,
>> David Pinheiro
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Advice-on-implementing-VRP-in-FOSS4G-tp6023900p6023900.html<http://osgeo-org.1803224.n2.nabble.com/Advice-on-implementing-VRP-in-FOSS4G-tp6023900p6023900.html?by-user=t>
>> Sent from the OSGeo Discuss mailing list archive at Nabble.com.
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=6023938&i=1>
>> http://lists.osgeo.org/mailman/listinfo/discuss
> Georepublic UG & Georepublic Japan
> eMail: [hidden email]<http://user/SendEmail.jtp?type=node&node=6023938&i=2>
> Web: http://georepublic.de
> [hidden email] <http://user/SendEmail.jtp?type=node&node=6023938&i=3>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1803224.n2.nabble.com/Advice-on-implementing-VRP-in-FOSS4G-tp6023900p6023938.html
> To unsubscribe from Advice on implementing VRP in FOSS4G, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6023900&code=ZGF2aWRzYW50b3NwaW5oZWlyb0BnbWFpbC5jb218NjAyMzkwMHwyMDcxNTIxNzE=>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Advice-on-implementing-VRP-in-FOSS4G-tp6023900p6060117.html
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20110224/d49f213a/attachment.html
More information about the Discuss
